Pocket E-Reader: Using reTerminal Sticky for Everyday Reading
A few stops on the train, a coffee break, or ten minutes before an appointment—there are plenty of small opportunities to read throughout the day. A pocket e-reader makes it easier to enjoy a few pages whenever you have a moment, without carrying a full-sized device.
In this blog, we’ll use reTerminal Sticky as an example to explore how a compact, open-source ePaper device can be turned into a pocket e-reader. We’ll look at its portable design and reading-friendly features, walk through the process of installing reader firmware, and explore other creative uses made possible by its open-source ecosystem.
What is reTerminal Sticky and Why Is It Suitable for Pocket Reading?
reTerminal Sticky is a 3.97-inch magnetic ePaper device developed by Seeed Studio. Designed as a compact, open-source display, it offers more possibilities than its original functionality.
With a compatible reading firmware like CrossPoint Reader, Sticky can also serve as a pocket-sized e-reader. Simply load your e-books onto a microSD card and read them on its e ink screen, picking up right where you left off.
So, what makes Sticky suitable for everyday reading? Let’s take a closer look at these features.
Compact Size and Lightweight for Easy Carrying
Lightweight and Pocket-Sized
Measuring 106 × 65.5 × 7.3 mm and weighing just 70 g, Sticky has a slim, card-style design that’s easy to hold in one hand or slip into a small bag compartment. Its lightweight build makes it convenient to carry for reading during commutes, breaks, or travel.
Flexible Ways to Carry
Sticky offers two convenient ways to keep it within reach:
Lanyard hole: Attach a wrist strap for easy carrying and quick access using the built-in hole.
Magnetic back: Use the included adhesive magnetic ring on a suitable phone case to attach Sticky to your phone. Detach it whenever you want to read.
A Small E-Ink Screen for On-the-Go Reading
The screen is another key factor in the pocket reading experience. Sticky features a 3.97-inch E Ink display with an 800 × 480 resolution and 235 PPI, delivering crisp text and clear details in a compact format. Its small screen keeps the device portable while providing enough room for reading on the go.
After installing a compatible reading firmware, you can further customize the font size and other display settings to suit your preferences. In the following section, we’ll use CrossPoint Reader as an example to walk you through the setup process.
Setting Up reTerminal Sticky as a Pocket E-Reader
As an open-source device, reTerminal Sticky supports several community-developed reading firmware options, including CrossPoint Reader, CrossInk, CrossMux, CrossLink, and EDC Book. For more compatible firmware options, check the firmware list.
CrossPoint Reader is an open-source e-reader firmware designed for compact E Ink devices. It adds book-reading capabilities and lets you customize your reading experience, making it a practical option for turning Sticky into a pocket e-reader.
Let’s walk through the installation and setup process.
What You Need to Get Started
- reTerminal Sticky
- A compatible microSD card for storing books (sold separately)
- A USB-C data cable for installing the firmware
- A computer with desktop Chrome or Edge
- A microSDcard reader (if you plan to copy books directly from your computer)
Note: A microSD card is not included. Third-party microSD cards ranging from 4GB to 256GB have been tested with FAT32 or exFAT formatting; If you need both a card and a reader, our suggested 32 GB Micro SD Card Tool Kit is a good option for you.
Setting Up CrossPoint Reader
- Prepare the card. Insert your formatted microSD card into Sticky before flashing CrossPoint.
- Connect and Flash. Open the CrossPoint firmware in Sticky Playground. Connect Sticky using the data cable, select the firmware version, and click Connect & flash easily.
- Start the reader. Keep the cable connected until it’s finished, and CrossPoint reader appears.
For the complete walkthrough, see the Sticky CrossPoint setup guide here.
Preparing Your E-Books for Offline Reading
Add your books
CrossPoint supports DRM-free EPUB, TXT, and XTC/XTCH files. You can add books in three ways:
- Via microSD Card: Copy your book files to the microSD card and insert it into Sticky. [Detailed guide here]
- Over Wi-Fi: On Sticky, go to File Transfer → Join Network and connect to the same Wi-Fi network as your phone or computer. Upload books through the browser address or QR code displayed on Sticky. iPhone and iPad users can also use the CrossPoint: Sync & Stats app.
- Using Calibre: Install the CrossPoint plugin in Calibre. Connect Sticky and your computer to the same Wi-Fi network, then select a book in Calibre and click Send to device.
Find a comfortable layout
Open Browse Files, select your EPUB, and open a chapter. Try a page at your usual font size, then adjust the line spacing or margins to see which layout you prefer. The top-right button wakes Sticky and acts as Enter/Confirm, while the two lower buttons navigate menus and turn pages.
Read offline
Turn pages using the physical buttons or by tapping either side of the screen. Once your books are saved on the microSD card, you can enjoy reading without Wi-Fi.
Beyond Reading, More Fun in Your Pocket with Sticky
Reading is just one way to use Sticky. Thanks to its open-source ecosystem, you can also turn it into a comic reader, portable writing device, gaming screen, personal dashboard, or a customizable everyday accessory.
Turn Sticky into a Pocket Comic Reader
The community-built XTC.js converter includes a preset for Sticky running CrossPoint. It lets you prepare manga and comic pages for the 3.97-inch screen, including splitting wide pages into smaller sections for easier viewing.
Turn Sticky into a Portable Writing Device
Solar OS by Marton offers a portable writing setup with “StickyTerm.” Pair Sticky with a compact keyboard for journal entries or short drafts away from your desk.
Turn Sticky into a Pocket Pokédex
A community-built Pokédex webpage powered by PokéAPI turns Sticky into a handheld Pokémon encyclopedia, with a retro-inspired layout optimized for its 4-level grayscale E Ink display.
A Pocket-Sized Prayer Time Display
Turn Sticky into a compact prayer time display, keeping daily prayer schedules easily accessible on its E Ink screen.
Is reTerminal Sticky the Right Pocket E-Reader for You?
At $49.90, reTerminal Sticky offers an affordable starting point for portable reading and open-source projects. However, you’ll need to purchase a microSD card separately. Your total cost may also depend on whether you already have a compatible data cable and card reader.
Sticky may be a good fit if you:
- Read in short sessions: Its lightweight 70 g design makes it easy to carry for a few pages on the train, during lunch breaks, or while traveling.
- Enjoy DIY projects: You’re comfortable installing reading firmware and like exploring community-built projects or printing your own case.
- Already own a larger e-reader: Sticky can serve as a compact companion for days when you’d rather leave your full-sized device at home.
A few things to consider before buying:
Getting started requires a firmware installation. The small screen also means more frequent page turns, especially when using larger fonts, and you’ll need an external light source for reading in the dark.
Ready to give it a try? Explore reTerminal Sticky or join the Sticky Facebook Community to discover community projects, and exchange ideas.
FAQs
Is a 4-inch e-reader too small for reading?
It depends on your preferred font size. A reflowable EPUB adjusts to reTerminal Sticky’s 3.97-inch screen, but larger type means fewer words per page.
Can reTerminal Sticky read EPUB files?
Yes. With CrossPoint Reader installed, Sticky can open DRM-free EPUB files stored on a microSD card. Text-based books can reflow to fit the screen, while illustrated pages may be harder to read at this size.
Does reTerminal Sticky have a front light?
No. You will need daylight or another external light source to read the screen. For reading in a dark room, use a bedside or reading lamp.
Can I read Kindle books on Sticky?
Sticky does not run the Kindle app. A book needs to be available in a supported, DRM-free format; an Amazon purchase does not automatically mean its downloaded file can be opened in CrossPoint.
Does Sticky support custom firmware?
Yes. Sticky supports official, partner, and community-developed firmware, all available in the Sticky Firmware Playground.
The factory firmware supports family notes, to-do lists, weather, and photo display. With compatible firmware, you can turn Sticky into a pocket e-reader, a personal dashboard, or a Home Assistant control panel. You can also write with a Bluetooth keyboard or play community-developed games.
Can I switch between CrossPoint and the original Sticky firmware?
Yes. Sticky Playground includes an official Seeedash firmware restoration option. Switching involves flashing the appropriate firmware again, so back up important content and expect to repeat setup where needed.
Read More <<
