Grove - 2-Channel SPDT Relay
Grove - 2-Channel SPDT Relay, switch,
$6.90
In stock
  • 10+: $6.21
  • 20+: $5.87
  • More
  • 50+: $5.52
  • Less
attention icon
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
The Grove - 2-Channel SPDT Relay has two single pole - double throw (SPDT) switches. It only requires low-voltage and low current signals to
control those switches. Specifically, you can use 5V DC to control max.250V AC or 110V DC.
The best thing is that you can control the two channels separately. For instance, controlled by SIG1, you can connect the COM1 to NC1 or NO1 as your wish.
It is so convenient and reliable that it can be applied to massive products or projects which need to switch high voltage/high current devices.
  • High temperature resistant plastic shell
  • High voltage load
  • Low power consumption
  • Long lasting
Applications
  • Domestic appliance
  • Office machine
  • Remote control TV receiver
  • Monitor display
  • Audio equipment high rushing current use application
Pin Map
Dimensions 40mm x40mm x19mm
Weight G.W 150g
Battery Exclude
Grove - 2-Channel SPDT Relay 1
Grove Cable 1
Acrylic Case 1
A bag of Nylonl nuts, studs and bolts 1
ECCN EAR99
HSCODE 85364110
USHSCODE 85364100
UPC 841454120872
This is the wiki of Grove - 2-Channel SPDT Relay
Product Faqs
Sort by
