Note:
Out of the Box: A Family Note Everyone Can See
A calm display for the little things that keep your family connected. It’s a shared low-distraction device for reminders, chores, or a simple “thinking of you” note—placed right where your loved ones pass by. Note, weather, time, and a rotating photo appear naturally, adding warmth without clutter. What matters always gets seen.
Speak to Add a Note or Reminder
Press and hold the AI button, then speak to create a note or set a reminder while Sticky is online.
Manage Your Sticky Anywhere with the Seeedash App
Send photos remotely from your phone with the Seeedash app. Create designs in Seeedash Web and deploy them to Sticky. When Sticky is online, photos and designs sync after you send them. If it’s asleep, they sync the next time it comes online.
Mount It Where Your Family Will See It
Attach Sticky directly to a magnetic surface, such as a compatible fridge door. For suitable flat, dry non-magnetic surfaces, use the included adhesive magnetic ring.
Seamless Touch Interaction on a Home-Friendly ePaper Display
Tap or swipe to navigate while Sticky is awake. If it’s asleep, press any physical button to wake it.
Community Firmware: More Ways to Use Sticky
| Parameter | Description |
| Display | 3.97-inch monochrome ePaper display, 4-level grayscale |
| Resolution | 800 × 480 |
| Interaction Method | Touch Control |
| Processor | ESP32-S3 |
| PSRAM | 8 MB |
| Flash | 32 MB |
| Supported Storage Card | MicroSD Card |
| Microphone | Single Microphone |
| Mounting Method | Built-in Magnet |
| Battery | 750mAh Lithium Battery |
| Charging Port | USB Type-C |
| Wireless | 2.4GHz Wi-Fi & BLE 5.0 |
| Dimensions | 106mm x 65.5mm x 7.3mm |
| Weight | 70g |
| Operating Temperature | 0°C to 45°C |
| reTerminal Sticky | ×1 |
| USB-C charging cable | ×1 |
| Adhesive magnetic ring | ×1 |
| Printed Quick Start Guide | ×1 |
reTerminal Sticky is a 3.97-inch AI-powered magnetic ePaper display that keeps your family connected through visible notes, to-do lists, weather updates, and thoughtful messages. Simply speak to create content, manage it remotely with the Seeedash App, and place Sticky wherever it matters most—so everyone can see what matters at a glance, without the distractions of another screen.
