PIR Motion sensor module
PIR motion sensor, motion sensor,pir sensor
$5.90
In stock
  • 10+: $5.31
  • 20+: $5.02
The PIR Motion sensor module is an automatic control module based on infrared technology. It adopts LHI788 probe, which has high sensitivity, high reliability, low voltage working mode and low power consumption. It can be widely used in various types of automatic induction electrical equipment.
The PIR Motion Sensor Series includes several products that will meet your different needs:
ProductMeasuring range
(theoretical value)
Grove - PIR Motion Sensor Max Distance:3-6m(3m by default)
Angle:< 120°
Measuring distance and holding time adjustable
response speed:0.3s - 25s
Grove-Adjustable PIR Motion Sensor Max Distance:3-6m
Angle:X=110° Y=90°
Grove - mini PIR motion sensor Max Distance:2-5m(2m by default)
Angle:X=110° Y=90°
Sensitivity adjustable
Mini-size
PIR Motion Sensor - Large Lens version Max Distance:9m
Angle:< 120°
Large lens which can support long range and wide angle
2.54mm standard connector
PIR Motion sensor module Max Distance:3-7m
Angle:< 120°
Measuring distance adjustable
Mini PIR Motion Sensor Module Max Distance:7m
Angle:< 100°
Mini-size
Applications
  • Switch
  • Motion sensor
  • Thief-guarding system
  • Industrial automation
Specifications
ItemValue
Input Voltage DC 4.5V ~ 20V
Static Current <50uA
Output Signal 0V / 3V (Output high when motion detected)
Sensing Range 7 meters (120 degree cone)
Delay time 8s ~ 200s (adjustable)
Operating Temperature -15℃ ~ +70℃
Dimensions 24mm*32mm*25mm(Height with lens)
Weight 6.6g
item value
Battery Exclude
PIR Motion sensor module 1
HSCODE 9031900090
USHSCODE 9027106000
UPC 841454105039
Product Faqs
Sort by
