Loading...
Water Flow Sensor YF-B4
Rating:
80% of 100
It consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal.
$6.90
In stock
  • 2+: $6.56
  • 10+: $6.21
  • More
  • 50+: $5.87
  • Less
Water flow sensor consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine.
Life is longer than plastic body.
• Compact, Easy to Install
• High Sealing Performance
• High Quality Hall Effect Sensor
• RoHS Compliant
TypeDimensions(DN)Working VoltageFlow Rate RangeLengthMale & FemaleLength of ThreadMaterial
YF-B1 DN15 5V~15V(DC) 1~25L/min 44mm Double Male 10mm Copper
YF-B2 DN15 5V~15V(DC) 1~25L/min 50mm Male in Female out 10mm Copper
YF-B3 DN15 5V~15V(DC) 1~25L/min 66mm Double Male 18mm Copper
YF-B4 DN15 5V~15V(DC) 1~25L/min 66mm Male in Female out 10mm Copper
YF-B5 DN20 5V~15V(DC) 1~30L/min 50mm Double Male 10mm Copper
YF-B6 DN20 5V~15V(DC) 1~30L/min 60mm Double Male 11mm Copper
YF-B7 DN15 5V~15V(DC) 1~25L/min 66mm Double Male 10mm Copper
G1&2 DN15 5V~24V(DC) 1~30L/min Double Male Plastic
G3&4 DN20 5V~24V(DC) 1~60L/min Double Male Plastic
G1&2 DN15 5V~24V(DC) 1~30L/min 60mm Double Male 13mm Plastic
G1&8 - 5V~24V(DC) 0.3~6L/min - - - Plastic
M11*1.25 - 5V~24V(DC) 0.3~6L/min - - - Plastic
Dimensions 0mm x0mm x0mm
Weight G.W 144g
Battery Exclude
Mini. Wokring Voltage DC 4.5V
Max. Working Current 15mA (DC 5V)
Working Voltage DC 5V~15V
Flow Rate Range 1~25L/min
Frequency F=(11*Q)Q=L/MIN±3%
Load Capacity ≤10mA (DC 5V)
Operating Temperature 0 ~ 80℃
Liquid Temperature ≤120℃
Operating Humidity 35%~90%RH
Water Pressure ≤1.75MPa
Storage Temperature -25~+ 80℃
Storage Humidity 25%~95%RH
Interface Dimensions G1/2Inch
Error Range (1~30L\MIN) ±3%
Material Description H57Copper+POM
Output Pulse High Level >DC 4.7V (Input Voltage DC5V)
Output Pulse Low Level <DC 0.5V (Input Voltage DC5V)
Output Pulse Duty Cycle 50%±10%
Water Flow Sensor YF-B4 1
HSCODE 9026100000
USHSCODE 9026106000
Documentations
Learn
You can find almost everything you need to know about the water flow sensor in this tutorial.
You can find dozens of water flow sensors on our website, so the question comes, which one is best for your project? Well, just take 5 minutes to read the blog and follow the simple 3 rules, all your doubts will be gone!
  1. Rating
    40%
    How difficult is to provide connector part no?!
    Actually it is:
    JST 3 Way 1 Row Straight Male Multiway Connector
    Mfr. Part No. SMP-03V-BC
    Mating receptacle part no:
    SMR-03V-B
    Ps. It may save someone a lot of time.
    By
1 Item
Show per page
