Please complete required options
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Weather Sensors
Based on your monitoring needs, select the most suitable sensor model from the table below.
Product
Air Temperature
Humidity
Barometric Pressure
Light Intensity
Wind Speed
Wind Direction
Rainfall
PM2.5
PM10
CO₂
Noise
Radiation
UV Index
S200
101991044
S500
101991021
S700-B
101991102
S700/ S700-A
101991022
S800
101991023
S1000
101991024
S2120
101990961
  • - Indicates the feature is available in the model.
/ - Indicates the feature is not available.
LoRaWAN® Weather Station
For all-in-one, hyperlocal weather monitoring, the SenseCAP S2120 is a robust, integrated solution.
Feature
Monitored Parameters
Air Temp & Humidity, Wind Speed & Direction, Rainfall, Light, UV Index, Barometric Pressure.
Power Supply
Solar-powered (0.5W) with AA battery backup (up to 2-year life); expandable for longer duration.
Durability
Robust design for harsh outdoor environments (UV, rain, and dust resistant).
Management
Easy on-site setup via Bluetooth; supports remote management and data access.
Deployment
All-in-one installation kit (poles, brackets) for flexible deployment.
Data Logger
When standard all-in-one sensors do not meet your specific requirements, you can use the following data transfer units or data loggers to easily connect your existing sensors to a LoRaWAN® or 4G network.
Solution
Use Case
Interfaces
Cable Connector
Network
SenseCAP S2100 LoRaWAN® DTU
Retrofit one or a few traditional wired sensors into low-power, long-range wireless nodes.
RS485/ Analog Input / GPIO
Hook-up wires
LoRaWAN®
SenseCAP Sensor Hub 4G Data Logger
Connect multiple RS485 sensors (up to 32) for centralized and stable data transmission over a 4G network.
RS485 (Modbus-RTU)
Aviation Connector
4G/LTE
Note: To connect a sensor to the Sensor Hub 4G Data Logger, you will need a sensor probe equipped with a dedicated aviation connector. For the LoRaWAN Data Logger, a junction box may be required to connect an external 12V power supply.
Gateway
Receives data from trackers and transmits it to the server via Ethernet/4G.
Selection Criteria
Quantity
A single Device covers a radius of 2-5 km. Estimate the quantity based on site area and obstacles.
Deployment Environment
Choose a device with the appropriate protection rating based on the gateway's deployment location (indoor/outdoor).
Power Supply
For outdoor locations without a power source, choose a gateway with a battery / solar power.
Network Conditions
Choose an Ethernet Gateway if a wired network is available.Choose a 4G Gateway for wireless or flexible deployments.
Frequency Band
[Required] Select the corresponding frequency band based on the project's country/region. Eg. EU - 863 , US - 915, Japan - 923
Server
The "brain" of the solution, responsible for data processing, storage, and visualization. If you use the SENSECAP , no additional local server is required.
Deployment Mode
Advantages
Requirements
SenseCraft Public Cloud (Recommended)
Simple, fast, maintenance-free, with API and open-source Software
Gateway requires internet access
Private On-Premises Deployment
Data is completely private and highly secure
Requires self-deployment of servers and certain technical skills
Application
SenseCraft provides a complete set of general-purpose tools compatible with the hardware, from device configuration and data reading to AI model deployment, making it easy to build your own solutions
Farmland Microclimate Monitoring
SKU E2025081901
Get hyper-local weather data for your farm. Our agricultural weather station tracks temperature, humidity, light, wind, and rainfall to support precision irrigation, pest management, and disaster prevention.
USD$0.00
Please select at least one option
