the AI Hardware Partner
Toggle Nav
Loading...
Seeed Studio XIAO SAMD21(Seeeduino XIAO) - Arduino Microcontroller - SAMD21 Cortex M0+ with Free Course
XIAO SAMD21 powered by SAMD21G18 chip is an ultra-small, high-performance universal development board, the pioneering product of the XIAO series. It supports Arduino / Micropython / CircuitPython development, which is the perfect microcontroller for you to get started with electronics.
Note
Features
  • High Performance: Powered by SAMD21G18 chip, operating up to 48MHz, equipped with 32KB of SRAM, and 256KB of onboard flash memory
  • Ultra-small Design: 21 x 17.5mm, Seeed Studio XIAO series classic form-factor, suitable for wearable devices
  • Multiple Development Interfaces: 11x analog / 11x digital Pins, 1x I2C interface, 1x UART port, and 1 SPI port
  • Multiple Develop Platform: Support Arduino / Micropython / CircuitPython development, friendly for beginners, satisfied for electronics enthusiasts
Seeed Studio XIAO SAMD21 carries the powerful CPU-ARM® Cortex®-M0+(SAMD21G18) running at up to 48Hz. In addition to the powerful CPU, it has 256KB Flash and 32KB SRAM on board and supports the USB Type-C interface which can supply power and download code.
Seeed Studio XIAO SAMD21 has 14 PINs, which can be used for 11 digital interfaces, 11 mock interfaces, 10 PWM interfaces (d1-d10), 1 DAC output pin D0, 1 SWD pad interface, 1 I2C interface, 1 SPI interface, 1 UART interface, Serial communication indicator (T/R), Blink light (L) through pin multiplexing. The colors of LEDs(Power,L,RX,TX) are green, yellow, blue and blue. Moreover, Seeed Studio XIAO SAMD21 has a Type-C interface which can supply power and download code. There are two reset button, you can short connect them to reset the board.
Except for the power LED, we add a user LED on board for your better coding experience. Usually, a dev board as small as this size will use the chip’s inner crystal oscillator for time fixing, in order to make the clock more accurate, Seeed Studio XIAO SAMD21 layouts an extra 32.768KHz to make the clock more stable.
Moreover, Seeed Studio XIAO SAMD21 is friendly to the communities for its strong software compatibilities, which supports Arduino, Micropython, and CircuitPython. Except for the software, flexible I/O allows it to speak to almost any external device.
Note
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Grove Shield for Seeed Studio XIAO. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. For example, you can make a Pocket Distance Alarm by connecting the Seeed Studio XIAO SAMD21 with a Seeed Studio Grove Shield for Seeeduino XIAO, a Grove - Circular LED, a Grove - Vibration Motor, and a Grove - Time of Flight Distance. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
By the way, we've set up a tinyml channel on our Discord server, please click to join for 24/7/365 making, sharing, discussing, and helping each other out.
Specification
Parameter Description
CPU ARM Cortex-M0+ CPU(SAMD21G18) running at up to 48MHz
Storage 256KB Flash,32KB SRAM
I/O PINs 14 GPIO PINs,11 analog PINs, 11 digital PINs, 1 DAC output Pin
Interface 1 I2C interface,1 UART interface, 1 SPI interface, USB Type-C interface
LEDs 1 user LED, 1 power LED, and two LEDs for serial port downloading
Reset button two reset buttons short connect to reset
Software compatibility Arduino IDE
Dimensions 21x17.5 mm
We already have 5 XIAO products based on different solutions in the Xiao family, to help you better understand the differences and choose the most suitable part for your projects, please refer to the Seeed Studio XIAO Series Page.
Application
  • Wearable devices
  • Rapid prototyping (directly attached to the expanded PCB as a minimal system)
  • Perfect for all the projects that need a mini Arduino
  • DIY keyboard
  • USB development (USB to multi-channel TTL/USB host mode, etc.)
  • In a scenario where you need to read multiple mock values The DAC output
Hardware Pinout
Seeed Studio XIAO SAMD21 1
Pasters 4
Demo
Attention
HSCODE 8517180050
USHSCODE 8543708800
UPC
EUHSCODE 8543709099
COO CHINA
CE 1
EU DoC 1
FCC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    Great product!
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    product deliverd before expected date. good experience
    By
  3. Product Quality
    100%
    Documentation
    100%
    from order view
    perfect! really small device.
    By
  4. Product Quality
    100%
    Documentation
    100%
    from order view
    Das Board ist einfach zu bedienen und unterstützt die Programmierung über die Arduino IDE oder die PlatformIO Entwicklungsumgebung. Es ist auch mit vielen Arduino-Schaltungen und -Platinen kompatibel, was es zu einer guten Wahl für Bastler und Entwickler macht.
    Alles in allem ist das Seeed Studio XIAO SAMD21 ein beeindruckendes Board, das viele Funktionen und Leistung in einem kleinen Paket bietet. Es ist eine großartige Option für diejenigen, die nach einem leistungsstarken, aber erschwinglichen Mikrocontroller-Board suchen.
    By
  5. Product Quality
    100%
    Documentation
    100%
    from order view
    Still in the package - will let you know
    By
Items 31 to 35 of 94 total
Show per page
