the AI Hardware Partner
Toggle Nav
Loading...
Seeed Studio XIAO ESP32S3 - 2.4GHz WiFi, BLE 5.0, 8MB PSRAM, 8MB FLASH, Dual-core, battery charge supported, power efficiency and rich Interface, ideal for Smart Homes, IoT, Wearable Devices, Robotics
Seeed Studio XIAO ESP32S3 leverages 240MHz Xtensa 32-bit LX7 dual-core processor, supporting both WiFi and BLE 5.0 wireless connectivities, a 2.4GHz Rod antenna, allows for deep sleep mode with power consumption as low as 14μA while supporting lithium battery charging management. Ideal for the Internet of Things, Smart Homes, Wireless wearable devices, Robotics, etc.
$7.49
In stock
  • 10+: $6.50
Feature
  • Powerful MCU Board: Incorporate the ESP32S3 32-bit, dual-core, Xtensa processor running at up to 240MHz, mounted multiple development ports, Arduino / MicroPython supported
  • Outstanding RF performance: Supports 2.4GHz WiFi and BLE 5.0 dual wireless communication, support 100m+ remote communication when connected with U.FL antenna
  • Elaborate Power Design: Lithium battery charge management capability, offer 4 power consumption model which allows for deep sleep mode with power consumption as low as 14μA
  • Thumb-sized Compact Design: 21 x 17.5mm, adopting the classic form factor of XIAO, suitable for space limited projects like wearable devices
  • Perfect for Production: Breadboard-friendly & SMD design, no components on the back
XIAO ESP32S3 is a high-performance board powered by Expressif ESP32-S3R8 chip. With support for 2.4GHz WiFi and low-power Bluetooth® BLE 5.0 dual-mode wireless communication, this board is perfect for high-performance, low-power IoT applications.
When connected with the U.FL antenna, the remote communication distance and reach up to 100m.
Equipped with a powerful Xtensa® 32-bit LX7 dual-core processor running at up to 240MHz, 8MB PSRAM, and 8MB Flash, XIAO ESP32S3 is designed to handle multi demanding tasks with ease.
Additionally, XIAO ESP32S3 supports lithium battery charging management and allows for deep sleep mode with power consumption as low as 14μA. With 4 adjustable power modes, XIAO ESP32S3 can balance communication distance, data rate, and power consumption to meet the needs of various application scenarios.
At just 21 x 17.5mm, XIAO ESP32S3 is designed with the classic thumb-sized form factor, making it perfect for wearable devices. Its breadboard-friendly and surface-mount design makes it ideal for production, with all SMD components on a single-sided board for ease of mass production.
Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
Application
  • Internet of Things
  • Wearable devices
  • Smart Homes
  • Robotics
  • Health monitoring
  • Education
  • Low-Power(LP) networking
  • Rapid prototyping
Specification
Parameter
Seeed Studio XIAO ESP32C3
Processor
ESP32-S3R8
ESP32-C3 SoC
Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz
Wireless
Complete 2.4GHz WiFi subsystem
BLE: Bluetooth 5.0, Bluetooth mesh
On-chip Memory
8M PSRAM & 8MB Flash
400KB SRAM & 4MB Flash
Interface
1x UART, 1x IIC, 1x IIS, 1x SPI,11x GPIO(PWM), 9x ADC, 1x User LED, 1x Charge LED
1x UART, 1x IIC, 1x SPI,11x GPIO(PWM), 4x ADC
1x Reset button, 1x Boot button
Dimensions
21 x 17.5mm
21 x 17.5mm
Power
Input voltage (Type-C): 5V
Input voltage (BAT): 4.2V
Circuit operating Voltage (ready to operate):
- Type-C: 5V@19mA
- BAT: 3.8V@22mA
- USB:5V@9mA
- BAT:3.8V@9mA
Charging battery current: 100mA
Charging battery current: 350mA
Low Power Consumption Model
(Supply Power: 3.8V)
Modem-sleep Model: ~ 25 mA
Light-sleep Model: ~ 2mA
Deep Sleep Model: ~ 14 μA
Modem-sleep Model: ~ 24 mA
Light-sleep Model: ~ 3 mA
Deep Sleep Model: ~ 44 μA
WiFi Enabled Power Consumption
Active Model: ~ 100 mA
Active Model: <75 mA
BLE Enabled Power Consumption
Active Model: ~ 85 mA
Modem-sleep Model: <27 mA
Working Temperature
-40°C ~ 65°C
-40°C ~ 85°C
Hardware Overview
Part List
XIAO ESP32S3
x1
Antenna
x1
Currently, all XIAOs don't come with a pin header. You can purchase them through Also add or pin header.
HSCODE 8517180050
USHSCODE 8543708800
UPC
EUHSCODE 8543709099
COO CHINA
CE 1
EU DoC 1
FCC 1
REACH 1
RoHS 1
TELEC 1
UK DoC 1
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    good product
    By
  2. Documentation
    100%
    Product Quality
    100%
    from order view
    These boards work great. The only downside I've run into so far is that to flash them, you need to unplug the cable, hold the _tiny_ boot button, plug in the cable, and then finally release the button. It's a real pain when flashing a lot during testing.
    By
  3. Documentation
    100%
    Product Quality
    100%
    from order view
    Everything is just fine.
    By
  4. Documentation
    100%
    Product Quality
    100%
    from order view
    I love these things. I never need more than 5-7 GPIOs but I always need smaller devices.
    I'd love to have a ESP32-S3 Sense with intergrated MPU and Microphone (similar to the nrf version here)!
    By
  5. Documentation
    100%
    Product Quality
    100%
    from order view
    Really small and of excellent quality. I haven't had the pleasure of using it yet.
    By
Items 6 to 10 of 79 total
Show per page
