Raspberry Pi Relay Board v1.0
Rating:
80% of 100
High quality relays of 15A max switching current Built-in LED indicator for each relay Optional I2C address through switch combinations Raspberry Pi compatible Relay screws for firm connection
$24.50
In stock
  • 10+: $22.05
  • 20+: $20.83
attention icon
Tip
This product is fully compatible with Raspberry Pi 4 (1GB, 2GB,4GB) and hopes you enjoy hacking with Pi 4 and all of other Pi 4 accessories.
The Relay Shield utilizes four high quality relays and provides NO/NC interfaces that control the load of high current. Which means it could be a nice solution for controlling devices that couldn’t be directly controlled by IIC bus. Standardized shield form factor enables smoothly connection with the Raspberry Pi . The shield also has four dynamic indicators show the on/off state of each relay.
  • Raspberry Pi compatible
  • Interface:IIC , Three hardware SW1 (1, 2, 3) select the fixed I2C-bus address
  • Relay screw terminals
  • Standardized shield shape and design
  • LED working status indicators for each relay
  • COM, NO (Normally Open), and NC (Normally Closed) relay pins for each relay
  • High quality relays
  • Working status indicators for each relay
Compatible:Raspberry Pi ; Other main board via jumpers;
Power supply:4.75~5.5V ;
Max Switching Voltage:30VDC/250VAC;
Max Switching Current:15A ;
Frequency:1Hz;
Dimensions:91.20 * 56.15*32mm;
Dimensions 130mm x60mm x32mm
Weight G.W 79g
Battery Exclude
Relay Board 1
HSCODE 85364110
USHSCODE 85364100
UPC 841454100089
This wiki is for Raspberry Pi Relay Board v1.0.
Customer Reviews
  1. Would not recommend
    Rating
    20%
    Circuit lacks any form of power supply bypass-capacitors at both the +5V and +3V3 rails, causing trouble when driving multiple relays with semi-inductive loads at the same time. I used this to switch a contactor and multiple solenoid valves but nearly every switch-cycle the IO-expander became unreachable on it's I2C interface (used power supply = 5A max). I've bodged on some 1uF capacitors and since then it worked flawless. Also, the dimensions of this board are based on a Pi 1 B, it will not fit in casing for a Pi 2 or 3. I also doubt how 'high quality' these Chinese unobtainable relays really are. 1/5 stars, would not recommend this board to anyone.
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
