Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Plug-and-play bundle: Assembled robot arm kit plus NVIDIA® Jetson AGX Thor™ Developer Kit, allowing on-site VLA model deployment such as GR00T, PI, OpenVLA etc.
  • Fully Open-Source: A truly 100% open-source 6+1 DoF robotic arm in terms of hardware and software. It includes BOM lists, hardware drawings, software, and algorithms—everything you need.
  • High-performance motors: 4 Damiao 4310 motors + 3 Damiao4340P high-torque, low-noise motors ensure stable and precise power for the reBot Arm B601-DM.
  • Framework Compatibility: Supports mainstream robotics development frameworks such as ROS1/2, Isaac Sim, and LeRobot.
  • Constant Content Updates: As the project progresses, we will gradually update the latest algorithms and launch a series of completely free courses.
⚠️Buying Guide
This is a fully assembled version, ready to use out of the box. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a desk/workbench. Please make sure to include one if you do not already have it. All other accessories are optional and can be purchased as needed.
reBot Arm B601-DM Assembled Kit with Gripper
Degrees of Freedom
6+1
Reach
767mm
607mm(without gripper)
Payload
1.5kg (without gripper, 70% reach recommended)
Joint Range of Motion
J1:±150°
J2:-220 - 0°
J3:-220 - 0°
J4:±90°
J5:±90°
J6:±90°
Gripper:-325° - 0°
Repeatability
0.2 mm
Weight
about 4.7kg
Servos
DM-J4340P-2EC x3
DM-J4310-2EC x4
Operating Temperature
-20°~50°
Power
DC 24V 10A
ROS1
Moveit1
ROS2
Moveit2
Python
Lerobot
Isaac Sim
Pinocchio
Open Source
Hardware Overview
Application
  • Voice control
By integrating the reBot arm with the NVIDIA® Jetson AGX Thor™ Developer Kit, you can deploy Large Language Models (LLMs) directly at the edge—enabling real-time, voice-controlled robotic operation. Powered by up to 2070 TFLOPS of AI performance and advanced language understanding capabilities, Jetson AGX Thor interprets natural language commands with high accuracy and seamlessly translates them into precise, real-time control signals for the reBot arm.
  • GraspNet Visual Grasping on Jetson
Powered by the NVIDIA Jetson AI edge computing platform and reBot Arm B601-DM, this embodied AI vision-based grasping solution enables intelligent robotic interaction with the physical world. By integrating RGB-D depth cameras (Orbbec Gemini 2), it delivers accurate and autonomous 3D perception and robotic grasping. The system integrates advanced technologies including YOLO-based object detection, 3D point cloud processing, the GraspNet-Baseline grasping algorithm, and hand-eye calibration, making embodied AI development more accessible for researchers and developers.
  • Teleoperation & Remote Robotics Control
The reBot Arm B601 enables intuitive teleoperation for remote manipulation, data collection, and human-in-the-loop training. Combined with AI robotics frameworks like Hugging Face LeRobot, it supports datasets and pre-trained model and policies, and imitation learning workflows that translate human actions into robotic behaviors, accelerating embodied AI development.
  • Assistive Automation for Home Daily Tasks
The reBot Arm B601 supports the development of assistive robotics for everyday tasks, from pick-and-place to simple household automation. By combining vision and learning-based control, the robot can adapt to unstructured environments and variable objects, helping bring embodied AI into practical, human-centered scenarios.
  • Precision Tasks in Harsh or Constrained Environments
With ±0.2 mm repeatability and stable actuation, the B601 is suited for precise tasks in challenging or unsafe environments. Developers can prototype applications such as inspection, sample handling, or fine manipulation under constrained conditions. Its support for dynamic motion execution enables more reliable interaction with uncertain or sensitive objects. This makes it a strong platform for validating robotics solutions before scaling to industrial systems.
  • Your Physical AI Project Deserves the Spotlight!
Seeed Studio's monthly "Physical AI Project of the Month" is now open for submissions—whether you're building with the reBot Arm (B601-DM/RS) or the SO-ARM (100/101), this is your chance to showcase your work to the global robotics community and get featured by Seeed Studio!
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
reBot Arm
Name
Quantity
Assembled Robotic Arm (with gripper)
1
Hex key wrench set
1
Mouse pad
1
[2%OFF] reBot Arm B601-DM Assembled Kit with Jetson Thor
SKU E26052001
reBotArm B601-DM, the Open-Source Robotic Arm with "Truely Open-Source" as its core, lowers the barrier to Embodied AI learning and development.delivers 1.5kg payloads, up to 767mm reach, and 0.2mm repeatability precision.
Paired with the NVIDIA® Jetson AGX Thor™ Developer Kit and 2070 TFLOPS computing power, this all-in-one bundle builds a high-performance physical AI deployment solution for robotic arms. Powered by the robust computing capability of Jetson AGX Thor, it supports seamless deployment of mainstream VLA models including GR00T, PI and more. It serves as a complete one-stop solution for field physical AI application scenarios.
2% off is automatically applied at checkout.
AI Computing Platform
USD$7157.00
reBot Arm B601-DM Assembled Kit with Gripper (Without Power Supply)x1$1599.00
Power Adapter Kit for reBot Arm B601-DMx1$59.00
NVIDIA® Jetson AGX Thor™ Developer Kit (945-14070-0080-000)x1$5499.00
You may also add
