Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
  • Powerful embodied AI Platform Compatible with the Jetson AGX Orin 32GB module, offering computing capability of 200 TOPS. Perfect platform for embodied AI and AMR
  • Multi-Connectivity Featuring 2x M.2 Key M slots for SSD, M.2 Key E slot for Wi-Fi and M.2 Key B slot for 4G/5G
  • Wide Voltage Input Range Can be used in 48V battery power system
  • Rich IO capabilities Includes most common IOs used in robotics and AMR prototyping, such as USB, 10G Ethernet, CAN, RS-232/422/485, I2C, SPI and I2S
  • Vision AI Support Features 4x 4-lane CSI output, and can be connected up to 8x GMSL2 cameras, making it ideal for vision AI applications such as BEV, Occupancy Grid, SLAM etc
Product
reComputer Robotics J5011 with GMSL Extension
Storage
2x M.2 Key M slot (1x 128G SSD included)
Networking
1x M.2 Key E slot for WiFi/Bluetooth module
1x M.2 Key B slot for 4G/5G module
I/O
USB
3x USB 3.0 Type-A (5Gbps);
1x USB 3.0 Type-C (Recovery);
1x USB 2.0 Type-C (Debug);
RJ45
4x 1G Ethernet
1x 10G Ethernet
GMSL
8x GMSL2 (MAX96712 as deserializer)
CAN
4x CAN (CAN-FD supported)
Serial
2x RS-232/422/485
DI/DO
4x DI 4x DO
IO
1x SPI 1x I2C 1x I2S
Display
1x HDMI 2.1
Fan
1x 4-pin Fan Connector (12V PWM)
Button
1x Reset Button; 1x Recovery Button
RTC
1x RTC 2-pin 1x RTC socket
Power
DC 19V ~ 48V Terminal Block 2-pin
Mechanical
Dimensions (W x D x H)
210mm*180mm*87mm (with stands)
Weight
2.95 kg
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
2 Year
Compatible GMSL Cameras supported in Jetpack
Manufactuer
Model
Resolution
Sensing
SG3S-ISX031C-GMSL2F
1920H*1536V
SG2-AR0233C-5200-G2A
1920H*1080V
SG2-IMX390C-5200-G2A
1920H*1080V
SG8S-AR0820C-5300-G2A
3840H*2160V
Orbbec
Orbbec Gemini 335Lg
3D
Hardware Overview
Application
  • Autonomous mobile robot
  • AI Robot Development
With AGX Orin module, this most powerful embedded AI system lets you create advanced robotics and edge AI applications for manufacturing, logistics, and healthcare. It’s the most powerful embedded system, pushing the limits of AI robotics. The Isaac robotics platform offers NVIDIA-accelerated systems, libraries, and generative AI models to enhance AI perception, manipulation, and simulation in robotics.
Learn about Issac platform
Isaac - AI Robot Development Platform | NVIDIA Developer
  • Multi-Sensor Fusion for Autonomous Mapping & Navigation
reComputer Robotics J501 supports sensor-rich autonomy by integrating data from LiDAR (via Ethernet/CAN), 3D cameras (via USB/CSI), GPS, and IMU (via UART). Using AI models and algorithms like ORB-SLAM,A-LOAM, NVBlox or Nav2, it performs sensor fusion, real-time localization, path planning, and obstacle avoidance. The low-latency processing on the AGX Orin SoC allows autonomous systems to adapt to changing terrain or obstacles on the fly. Its wide voltage input and compact form factor make it suitable for mobile deployment, enabling robust, edge-level autonomy without external compute.
  • Designed for demanding AI applications:
Such as AMR, smart retail, industrial automation, and video surveillance, smart video analysis scenario
The NVIDIA Isaac™ platform delivers the NVIDIA® CUDA®-accelerated libraries, application frameworks, and AI models you need to create autonomous mobile robots (AMRs), arms and manipulators, humanoids, and more.
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates (Upgrade to JetPack7.2), and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
x1
AGX Orin 32GB
x1
128GB SSD
x1
Terminal block to DC power cable
x1
USB Type-C to Type-A cable
x1
Panel Mount
x2
DIN Rail
x1
reComputer Robotics J5011 with GMSL - Ultra-Advanced Edge AI Computer with NVIDIA Jetson AGX Orin 32GB
SKU 100076722
reComputer Robotics J5011 is a power edge box with NVIDIA Jetson AGX Orin™ 32GB module. It features rich IOs, such as USB, Ethernet, CAN, RS-232/422/485, DI/DO and GMSL. It also features connectivity M.2 Key E slot for Wi-Fi/BT and M.2 Key B slot for 4G/5G modules, making it perfect candidate to be the brain of sophisticated mobile robots or autonomous vehicles.
Feel free to contact us for Non-GMSL version
USD$3049.00
You may also add
