For industrial-grade sensors that require integration, the SenseCAP S210X series LoRaWAN sensor products can be deployed out of the box.
Product | Air Temp | Air Humidity | CO₂ | NH₃/ H₂S | Soil Temp | Soil Moisture | Soil EC | Pore EC | pH | Probe Temp | Light |
S2101 | ✅ | ✅ |
S2102 |
S2103 | ✅ | ✅ | ✅ |
S2105 |
S2106 |
S2107 |
S2108 |
When standard all-in-one sensors do not meet your specific requirements, you can use the following data transfer units or data loggers to easily connect your existing sensors to a LoRaWAN® or 4G network.
Solution | Use Case | Interfaces | Cable Connector | Network |
SenseCAP S2100 LoRaWAN® DTU | Retrofit one or a few traditional wired sensors into low-power, long-range wireless nodes. | RS485 / Analog Input / GPIO | Hook-up wires | LoRaWAN® |
SenseCAP Sensor Hub 4G Data Logger | Connect multiple RS485 sensors (up to 32) for centralized and stable data transmission over a 4G network. | RS485 (Modbus-RTU) | Aviation Connector | 4G/LTE |
Note: To connect a sensor to the Sensor Hub 4G Data Logger, you will need a sensor probe equipped with a dedicated aviation connector. For the LoRaWAN Data Logger, a junction box may be required to connect an external 12V power supply.
Receives data from trackers and transmits it to the server via Ethernet/4G.
Selection Criteria | Description |
Quantity | A single Device covers a radius of 2-5 km. Estimate the quantity based on site area and obstacles. |
Deployment Environment | Choose a device with the appropriate protection rating based on the gateway's deployment location (indoor/outdoor). |
Power Supply | For outdoor locations without a power source, choose a gateway with a battery / solar power. |
Network Conditions | Choose an Ethernet Gateway if a wired network is available. Choose a 4G Gateway for wireless or flexible deployments. |
Frequency Band | [Required] Select the corresponding frequency band based on the project's country/region. Eg. EU - 863 , US - 915, Japan - 923
The "brain" of the solution, responsible for data processing, storage, and visualization. If you use the SENSECAP , no additional local server is required.
Deployment Mode | Advantages | Requirements |
SenseCraft Public Cloud (Recommended) | Simple, fast, maintenance-free, with API and open-source App | Gateway requires internet access |
Private On-Premises Deployment | Data is completely private and highly secure | Requires self-deployment of servers and certain technical skills |
Improve breeding efficiency, reduce disease and labor costs, and ensure stable and increased income from farming.
