Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Plug-and-Play Convenience: Features a mainstream USB Type-C interface for PC connection and a 3-pin screw terminal (GND, CAN_H, CAN_L) for quick field wiring.
  • High-Speed Stability: Built with an industrial-grade WCH CH340 USB driver and a high-performance GD32 (GigaDevice) MCU, supporting serial baud rates up to 921600 bps for real-time motor control.
  • Compact & Robust: Features a high-quality black immersion gold PCB design with reserved SWD debugging pins for advanced users who wish to customize the firmware.
  • Broad Compatibility: Specifically optimized for debugging RobStride series motors, but compatible with most CAN-bus based actuators and sensors.
Note: This module is designed exclusively for use with the official host software; the serial communication protocol documentation is not provided. For custom development or secondary programming, please use a standard CAN adapter (e.g., CANable) to control devices via standard CAN protocols. Customization services are available upon request.
Specification Item
Details
Product Name
RobStride USB-to-CAN Adapter
Input Interface
USB Type-C (5V Power Supply)
Output Interface
3-Pin Screw Terminal (GND, CAN_L, CAN_H)
Main Controller
GD32 Series (ARM Cortex-M)
USB Driver
WCH CH340
Max Serial Baud Rate
921600 bps
Net Weight
~10g
Application
  • Robotic joint motor debugging (e.g., RobStride series).
  • CAN bus data analysis and sniffing.
  • Firmware OTA updates for CAN devices.
Certification
HSCODE8517799000
USHSCODE8517690000
UPC
EUHSCODE8517180000
COOCHINA
  • RobStride USB-to-CAN Module x1
RobStride USB-to-CAN Adapter Module (Type-C, Offical GUI debug Tool Support)
SKU 100012096
The RobStride USB-to-CAN Adapter is a compact, cost-effective debugging tool designed for robotics engineers and makers. Powered by a GD32 MCU and CH340 driver, it features a modern USB Type-C interface and a 3-pin terminal block for easy connectivity. It supports offical control software, making it incredibly easy to control motors, read sensor data, and perform firmware updates without complex protocol stacks.
USD$15.00
