Best Home Assistant Hardware 2026 for Building a Smart Home
By Liyan Gong Last Updated on: April 30, 2026In the world of smart homes, selecting the right hardware is crucial for ensuring stable and efficient system performance. Home Assistant, an open-source smart home platform, is beloved by developers and users worldwide, and its associated hardware continues to evolve and improve.
This article will delve into several hardware products suitable for Home Assistant, including Home Assistant Green, Yellow, Home Assistant Voice Preview Edition, Connect ZBT-2 USB Stick, mmWave Human Detection Sensor Kit, Raspberry Pi 5, and other recommended products, to help you build your ideal smart home system.
Home Assistant Green and Home Assistant Yellow: Simple and Efficient Smart Home Control Centers
Home Assistant Green is a plug-and-play controller designed for smart home enthusiasts who are new to the technology or have basic needs. It comes with the Home Assistant operating system, allowing you to manage and control your smart devices without relying on cloud services. Now, for just $198.90, you can purchase it at Seeed. The price of US warehouses and European warehouses is the same, and import duties included!
🎉For a limited time, enjoy $2 OFF the Home Assistant Green with the code QWAS26OF at checkout! Plus FREE Shipping. Hurry, deals won’t last.
- Entry-Level Model: Ideal for beginners and average users, Home Assistant Green provides a straightforward solution for most smart home needs. It offers essential features and functionality, making it easy to set up and use right out of the box.
- Capabilities: Despite its simplicity, it supports a range of smart devices and basic automation scenarios. It’s powerful enough for typical smart home setups but remains user-friendly, requiring minimal configuration.
- Ease of Use: The device is designed to be user-friendly, making it accessible for those who prefer not to spend much time on DIY hardware or complex setups. It’s perfect for users looking to get started with smart home automation without a steep learning curve.
Home Assistant Yellow is the advanced version of the Home Assistant controllers, aimed at users with more demanding smart home needs. It features a more robust processor and additional expansion options.
- Advanced Model: Home Assistant Yellow is designed for those who need more power and flexibility. It includes enhanced hardware capabilities and supports expansion modules, such as the Zigbee module, to handle complex automation scenarios and manage a larger number of devices.
- Enhanced Features: This model supports advanced automation rules and can integrate with a wider variety of smart devices. Its powerful processor and additional memory make it suitable for handling more intricate setups and a higher volume of connected devices.
- Flexibility and Expansion: Home Assistant Yellow provides greater flexibility and expansion options compared to Home Assistant Green. It allows for more sophisticated configurations and automation, catering to users who require a more customized and comprehensive smart home system.
Update on October 16, 2025: Home Assistant has officially announced the discontinuation of the Home Assistant Yellow. If you’re looking for hardware that’s both easy to start with and supports the Open Home Foundation, we’d recommend the Home Assistant Green.
Learn more about what is the difference between home assistant green and yellow
- Built for Home Assistant: The first voice hardware designed by the team driving the development of Home Assistant, and built from the ground up to work with Home Assistant.
- The easiest way to start with Assist: Just connect it to USB-C power (cable and power supply not included) and it will connect with Home Assistant via an intuitive installation wizard. No assembly required.
- The private voice assistant: Pairing Voice Preview Edition with powerful Home Assistant hardware can allow it to run fully locally, or offload its audio processing to the privacy-focused Home Assistant Cloud.
The Home Assistant Connect ZBT-2 is the next-generation Zigbee & Thread USB radio from Nabu Casa, designed specifically for Home Assistant. It connects via USB-C to your Home Assistant hub (e.g., Green / Yellow / Raspberry Pi) to build a fast, reliable, and fully local smart home network. Up to 4× faster than the previous generation ZBT-1 (SkyConnect), with enhanced RF performance and stronger connections. Available now at Seeed for just $49.
- 4x faster than ZBT-1: Powered by the cutting-edge Silicon Labs MG24 SoC and ESP32-S3 USB bridge, the ZBT-2 delivers lightning-fast responses, ultra-low latency, and seamless smart home control. Learn more about Home Assistant Connect ZBT-2 vs ZBT-1
- Dual-Protocol Power in One Device: Enjoy Zigbee 3.0 and Thread connectivity in a single device — natively integrated with Home Assistant’s ZHA and Thread systems. ZBT-2 is fully Matter-ready, future-proofing your entire smart home ecosystem.
- Extended Range. Exceptional Stability: Equipped with a 4.16 dBi omnidirectional high-gain antenna, ZBT-2 easily penetrates walls and extends coverage across multiple rooms. Its orientation-sensing feedback ensures the antenna always performs at peak efficiency — guided by a gentle LED indicator.
The Home Assistant Connect ZWA-2 is a dedicated Z-Wave radio adapter designed for superior smart home performance, featuring an optimized, long antenna and the latest Z-Wave 800 chip to support standard and Long Range Z-Wave devices. Released by the Home Assistant team, it ensures high-reliability, local control for Z-Wave networks. Available now at Seeed for just $69.
- Unparalleled Range and Coverage: Engineered with a high-performance, oversized antenna, the ZWA-2 pushes signal through thick walls and across long distances, eliminating dead spots where other controllers fail.
- Rock-Solid Network Stability: By operating on the dedicated Z-Wave® frequency, the ZWA-2 avoids the congested 2.4GHz band, shielding your smart home from Wi-Fi and Bluetooth interference for flawless, reliable communication.
- Future-Proof and Globally Compatible: Ready for any setup, the ZWA-2 supports both traditional Z-Wave® mesh and the groundbreaking Z-Wave® Long Range protocol. With automatic region configuration when used with the Z-Wave® JS add-on, it’s the single, definitive controller for users anywhere in the world.
The mmWave Human Detection Sensor Kit utilizes microwave technology to detect human presence through minimal movement. This advanced sensor excels in environments where traditional infrared sensors might fail, such as through walls or glass. Purchase it today for just $22.94 at Seeed.
- Precision Detection: It can accurately detect human movement, making it ideal for applications like security monitoring, energy-efficient lighting, and automated climate control. For instance, it can automatically activate lights or adjust the thermostat when it detects occupancy, leading to increased energy efficiency and enhanced home automation.
- Versatile Use: Its ability to function through obstacles means it can be used in various settings, including complex or hidden locations, providing reliable detection regardless of the physical barriers in the environment.
Are you finding an home assistant server alternative to Home Assistant Green and Yellow?
The Raspberry Pi 5 stands out as a top choice for those who enjoy DIY projects and want to build a customized Home Assistant system. Its powerful hardware and extensive connectivity options make it suitable for a wide range of smart home applications. You can buy the Raspberry Pi 5 8GB for $175 or the Raspberry Pi 5 16GB for $305 at Seeed right now.
- High Performance: With its advanced processing power and 8GB/16GB of RAM, the Raspberry Pi 5 can handle multiple tasks and complex automations without performance issues. This makes it ideal for users who want to integrate numerous sensors, cameras, and other devices into their smart home setup.
- Customization and Flexibility: It offers unparalleled flexibility, allowing you to tailor your Home Assistant system to meet specific needs, whether you’re implementing intricate automation rules or connecting a variety of smart devices. The Raspberry Pi 5 also supports a wide range of add-ons and peripherals, enhancing its functionality and adaptability for different smart home scenarios.
Other Recommended Home Assistant Devices
In addition to the above, the following devices are also well-suited for Home Assistant systems, further enhancing your smart home experience:
reTerminal E1001 and reTerminal E1002
7.5 inch open-source ePaper display with up to 3-month battery life. Powered by ESP32-S3, it natively supports our SenseCraft HMI no-code UI platform for effortless dashboard creation, while supporting Home Assistant, TRMNL E-ink dashboard, Arduino and ESP-IDF for further development.
💥 Early bird special: $10 off if you order now.
Touchscreen terminal devices based on Raspberry Pi, allowing Home Assistant to be installed on a palm-sized device or mounted on a wall for convenient control.
A mini PC with powerful processing and extensive interfaces, ideal for running high-performance applications like Home Assistant.
A mini router supporting Docker, where you can run Home Assistant Docker containers, offering strong network features.
A compact microcontroller for creating custom smart home nodes, easily integrated with Home Assistant.
A sensor hub displaying and managing environmental data, perfect for monitoring and automating responses.
Summary: Choose the Right Hardware Based on Your Needs
Selecting the right hardware is key to building an effective smart home.
- Home Assistant Green and Yellow offer plug-and-play solutions for various user needs.
- Home Assistant Voice Preview Edition offers a privacy-focused, open-source voice assistant that seamlessly integrates with Home Assistant.
- SkyConnect / Connect ZBT-1 USB Stick supports Zigbee and Z-Wave networks.
- mmWave Sensor Kit provides enhanced security and energy efficiency;
- and Raspberry Pi 5 offers limitless possibilities for DIYers.
- Additionally, reTerminal Series, Odyssey, LinkStar, XIAO ESP32C3, SenseCAP Indicator provide diverse hardware options to enhance your smart home system.
Whether you are a beginner or an experienced user, these devices can help you create a high-performance, stable smart home system.
Tired of jumping between multiple pages just to complete a purchase?
Check out this curated Home Assistant starter kit that combines Home Assistant Green with the most essential daily devices. By pre-integrating high-performance hardware, the setup process is simplified—eliminating the frustration of manual driver debugging. From intelligent gateways and ambient displays to various sensors, this kit provides a ready-to-use foundation for a responsive, private, and fully automated sanctuary in minutes.
Liyan Gong
10 years in the IoT hardware industry. I’m here to share practical guides on Robotics arm, Home Assistant, NVIDIA Jetson, Meshtastic/Meshcore, Raspberry Pi, LoRa, PCB/PCB Assembly and more to help bring your creative ideas to life.
