Monthly Wrap-Up for December 2025: Edge Intelligence, Open Collaboration, and Future Infrastructure
By Ethan Zhou 5 months agoHey community,
Welcome to our December of 2025 Monthly Wrap-up! The past two months have been nothing short of inspiring—from innovations to global events across communities, we’ve seen new products hit the shelves, amazing open-source builds take shape, and plenty of collaborations pushing the boundaries of what’s possible.
In this issue, you’ll find 16 deep-dive explorations packed with insights, 1 engaging livestreams, and 9 product and service spotlights. On top of that, don’t miss 15 standout community projects that showcase the brilliance of makers worldwide.
Let’s dive into the highlights and celebrate another month of open-source spirit together!
01. Getting Started with XIAO ePaper Display EN04
Powered by XIAO nRF52840 Plus, the display board EN04 supports both 24-pin and 50-pin ePaper displays. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, NFC function and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital signage, electronic labels, and portable information boards.
02. SenseCAP T2000 Tracker Introduction
SenseCAP T2000, an industrial-grade LoRaWAN® asset tracker, supports GNSS, Bluetooth and Wi-Fi positioning for reliable tracking across indoor and outdoor environments. It features IP67 protection, a built-in 3-axis accelerometer that detects the motion status, and an anti-tamper button that triggers a top-priority alarm if the device is removed.
03. Deploying AI Models on SenseCAP A1102 Using SenseCraft AI
The SenseCAP A1102 is a powerful sensor device that combines advanced AI capabilities with ease of deployment. This guide will walk you through deployingofficial or custom AI models on the A1102 using the SenseCraft AI website, offering step-by-step instructions for pairing, configuration, and testing.
04. Play Subway Surfers with Body Sensor Control
05. Deploy Facial Recognition on reComputer
This wiki will guide you through using a reComputer equipped with a Hailo NPU to implement real-time facial recognition. In this project, we use SCRFD-10G for efficient face detection, capable of quickly and accurately detecting faces of various scales, including small faces, ensuring real-time performance.
This guide demonstrates how to integrate your existing business systems with SenseCAP Watcher through MCP (Model Context Protocol). Unlike the basic calculator example, this tutorial focuses on a industrial use case: voice-controlled warehouse management.
07. Getting Started with COB LED Driver Board for Seeed Studio XIAO
This is a 7-channel COB LED driver dock designed for Seeed Studio XIAO. This expansion board breaks GPIO power limits, offering 7 output channels, specifically tailored for ultra-narrow 1mm 3V COB LED strips. With integrated PMIC battery management, it is the ideal plug-and-play solution for building compact, high-brightness wireless lighting setups.
08. WHEELTEC IMU IMU Sensor Getting Start
The WHEELTEC H30 is a high-precision attitude sensor designed to accurately measure key data of carriers, including 3D attitude angles, acceleration, angular velocity, and magnetic field strength. Engineered with industrial-grade reliability, this sensor integrates a 3-axis MEMS gyroscope, a 3-axis MEMS accelerometer, and a 3-axis magnetic sensor—delivering robust performance for professional applications.
Seeed Studio XIAO Debug Mate is an open-source ESP32-S3 multi-tool that simplifies embedded system debugging with visual feedback. This all-in-one device features a standalone 2.01 inch TFT LCD display, LED status matrix, and native Seeed Studio XIAO support, delivering essential debugging functions.
10. Smart Retail Voice AI
Leverage Seeed’s Smart Retail Voice AI solution to capture and analyze in-store customer conversations. Our edge AI technology enables on-device speech-to-text processing, transforming voice data into actionable insights without relying on cloud services. Enhance customer experience, optimize store operations, and gain valuable feedback with our offline AI-powered voice analytics tailored for retail environments.
11. Getting Started with Seeed Studio XIAO ESP32-C5
This document introduces the getting-started process for the Seeed Studio XIAO ESP32-C5, including hardware overview, development environment setup, board configuration, and basic example uploads. It also covers power options and fundamental features, providing users with a straightforward reference for initial development with the XIAO ESP32-C5.
This project delivers a fully local smart voice assistant for offices and public spaces. It combines the ReSpeaker XVF3800 microphone array with on-device speech recognition and a local language model for completely offline operation. Real-time voice responses ensure natural interaction while maintaining privacy and low latency, making it ideal for secure environments like offices, malls, and meeting rooms.
13. XIAO ESP32 C5 ESP-Mesh Audio
This document demonstrates how to use the Seeed Studio XIAO ESP32-C5 to implement audio transmission over an ESP-Mesh network on the 5 GHz Wi-Fi band. It explains setting up a mesh scenario with the XIAO ESP32-C5 as a root node and a computer as a child node, shows an Arduino example for receiving UDP audio data, and includes a Python script to send simulated audio packets to the board.
14. Viseron on reComputer
Viseron is a self-hosted, local only NVR and AI Computer Vision software implemented in Python. The goal of Viseron is to be easy to setup and use, while still being powerful and flexible. It is designed to be run on a local network, with no external dependencies, and no cloud services required.
15. Getting started with the Two-Wheeled Biped Robot Based on the StackForce Development Platform
The StackForce two-wheeled biped robot is developed based on the StackForce lightweight robotics development platform. Its core hardware is composed of the StackForce series main control board, motor driver board, and servo driver board. The product provides complete installation tutorials and video courses, making it a cost-effective desktop two-wheeled biped robot.
16. HighTorque Motors Getting Started
This document explains how to power, wire, and safely set up the HighTorque motor, and how to use the debugging assistant software to calibrate it, tune parameters, control different operating modes (position, speed, torque, etc.), and perform basic FDCAN communication.
🎬 II. Weekly Livestream: Making Next Gadget
01.Making Next Gadget: No Code to Build Your ePaper Dashboard from Scratch
This holiday workshop teaches no-code UI design using the upgraded Sensecraft HMI platform and XIAO ePaper DIY Kits, suitable for all skill levels. Participants learn to build custom ePaper projects and design dashboards without coding through hands-on, step-by-step guidance. A Christmas giveaway offers four prizes: two reTerminal E1001 Monochrome ePaper Displays and two XIAO EE04 ePaper DIY Kits with ESP32-S3 based boards.
1.Seeed SenseCAP: Making Greenhouse Data Work for Daily Growing Decisions
In many greenhouses, decisions are still made by looking at the plants.
But intuition doesn’t scale, data does. In the Philippines, growers are using real micro-climate data to compare blocks, test changes, and turn experience into repeatable results. With Seeed’s SenseCAP sensor network and edge AI, data becomes part of daily growing decisions, not just reports.
02. The “Kleines Board ganz groß – der XIAO ESP32-C3” Is Now Released
We’re excited to announce the release of “Kleines Board ganz groß – der XIAO ESP32-C3”, a brand-new German-language book dedicated to our XIAO ESP32-C3. Created by Bombini Verlag in collaboration with electronics expert Dr. Günter Spanner, this hands-on guide helps beginners get started step by step—right in their native language. From flashing firmware and dimming LEDs to using ADC/PWM for sensor control, the book makes learning embedded development approachable and practical.
03. The SenseCAP LoRaWAN Asset Tracker T2000 Series
The SenseCAP LoRaWAN Asset Tracker T2000 Series delivers reliable indoor and outdoor positioning through WiFi, Bluetooth, and GNSS technology. Built for demanding environments, it features multi-year battery life, rugged housing, and remote management with smart alerts. Three specialized models enable teams to track and monitor construction equipment, field infrastructure, vehicles, logistics, livestock, and agricultural assets at scale.
04. Big AI Power, Small Robotic Brain — reComputer Robotics J4012
The reCompute Robotics J4012, powered by NVIDIA Jetson Orin NX 16GB, delivers up to 157 TOPS of edge AI performance in a compact system. It features plug-and-play connectivity via USB, Ethernet, CAN, and GMSL, with pre-installed JetPack 6.2 for quick deployment. Designed for demanding environments with wide power input and multi-camera support, it’s ideal for autonomous robots, industrial automation, smart retail, and edge AI vision applications.
05. Introducing the NEW reSpeaker XMOS XVF3800 with Acoustic Case & Pre-soldered XIAO ESP32S3!
06. Amazing Hand: A Handy Tool for Your Next Robotics Project
07. Meet SenseCAP S200
Accurate wind data is essential for smarter farms, safer cities, and resilient infrastructure. The SenseCAP S200 uses ultrasonic sensing with no moving parts for reliable performance in harsh conditions. With IP66 rating, -40°C to +85°C operation, and RS485/SDI-12 interfaces, it integrates seamlessly into agriculture, urban systems, renewable energy, and transportation applications.
08. SenseCAP S2120: Making Professional Weather Monitoring Simple and Accessible
The SenseCAP S2120 8-in-1 LoRaWAN Weather Sensor delivers reliable climate monitoring by measuring temperature, humidity, wind, rainfall, pressure, light, and UV in one device. With 1-minute setup, solar power, 2-year battery life, and 2–10 km LoRaWAN range, it’s ideal for agriculture, research, and urban applications. Compatible with Helium, TTN, and ChirpStack for seamless data-driven decisions.
09. XIAO ePaper DIY Kit-EN04: Plug-and-Play Display Solution
The XIAO ePaper DIY Kit-EN04 simplifies display projects with plug-and-play compatibility for Arduino, PlatformIO, and ESPHome. Powered by XIAO nRF52840 Plus, it supports ePaper displays up to 7.5″ with built-in NFC for tap-to-configure updates and three customizable keys for interactive control. Perfect for low-power applications like digital signage and portable dashboards, the EN04 makes building display projects effortless.
IV. Community Project Spotlight
The Breathing Origami Lamp (Fab Academy 2024) uses “Calm Technology” to guide stress-reducing 4-7-8 breathing through rhythmic light and motion. Powered by the XIAO ESP32-C3, it seamlessly integrates complex mechanics and custom electronics into a minimal, non-intrusive form designed for daily well-being.
Zeller’s new Mood Player blends music, motion, and visuals using our XIAO ESP32S3 Plus, the XIAO Expansion Board (with built-in OLED), Grove Speaker, and a Grove Button.
KidsSafe GPS Tracker is a project created by community member Jamie Dowden-Duarte, focusing on child safety during outdoor family activities such as camping and hiking,helping parents feel more confident while exploring nature with their children.
04. Tiny Pixel Desk Light
What if a handful of LEDs could completely change your workspace? Gokul KB’s Tiny Pixel Desk Light is a cute, compact RGB lamp powered by our XIAO ESP32C3 and 22 ultra-small WS2812B (2020) LEDs. Designed as a fun yet polished desk accessory, it delivers smooth, aurora-style lighting effects driven by custom NeoPixel code—all controlled by our tiny but powerful XIAO.
Explore more.
Instead of passively waiting for a 3D print to finish, Riichiro’s system lets a user dance and DJ with the 3D printer as it prints, creating responsive, co-created physical pieces that carry traces of real-time interaction. This is a fresh, playful take on movement as both input and output — making the process itself part of the creative outcome.
06. AI-powered Wearable Built on XIAO nRF52840 Sense
Solomon Githu’s project turns that idea into reality with an AI-powered wearable built on our XIAO nRF52840 Sense. Worn on the wrist, the device uses its onboard 6-DOF IMU to capture hand movements and runs a machine-learning model locally—trained with Edge Impulse—to recognize gestures like circular and left-right motions in real time.
07. Smart Pet Devices Dashboard
Built by Lewin Day on the reTerminal E Series, Epaper-Catto-Dashboard is an open-source project that turns everyday data from smart pet devices into a calm, always-on e-paper dashboard. By pulling weight and litterbox usage data via APIs, it transforms raw numbers into long-term, glanceable insights while maintaining ultra-low power consumption.
Gokul KB’s Time Since Wedding – E-Paper Clock is a beautifully minimal DIY project that tracks how many hours and days have passed since a wedding, instead of showing the current time. Built with our XIAO ESP32C3 and a low-power e-paper display, the clock stays always visible while consuming very little energy—perfect as a meaningful desk or shelf gift.
09. Compact Wi-Fi GPS Tracker
This project from Electroscope Archive shows how to build a compact Wi-Fi GPS Tracker using our XIAO ESP32-S3 and a Neo-6M GPS module. Instead of cellular networks, it sends location data over Wi-Fi to the GeoLinker cloud, where you can view routes, set geofencing zones, and trigger SMS alerts when boundaries are crossed.
10. Turn A Smartphone into A Steering Wheel for A Tiny Car
Michael Merrifield’s Microcar is a playful yet clever engineering experiment powered by our XIAO ESP32S3. Instead of wheels and DC motors, the car is driven using linear actuators and magnetic coupling, translating motion beneath the surface into movement above it. With a mix of simple electronics, 3D-printed parts, and a lot of curiosity, the project turns a small desktop build into a surprisingly expressive remote-control experience.
This electric spinning wheel transforms raw wool fibers into single-ply yarn of varying thicknesses, addressing a long-standing gap between large industrial machines and expensive, labor-intensive hand tools.
12. A Rugged, Modular Enclosure Designed for the Wio Tracker L1
This project introduces MeshPack — a rugged, modular enclosure designed for the Wio Tracker L1, enabling greater flexibility for outdoor and field deployments.
13. Smart Wi-Fi ePaper Scoreboard
Perfect for school competitions, indoor sports, and maker projects, the entire build requires zero soldering—just plug in the display, flash the code using Seeed’s GFX library + configuration tool, and assemble the 3D-printed frame. With a fully responsive control page served directly from the ESP32S3, you can update everything in seconds from any device.
What if you could build your own smartwatch—no custom PCB, no complex hardware—just pure maker creativity? Hari R.’s Graytimer is a DIY ePaper watch powered by our ultra-compact XIAO nRF52840, featuring a 1.54″ GoodDisplay ePaper screen, DS3231 RTC, and a LiPo battery packed neatly into a 3D-printed case. This minimalist build refreshes the display every minute and automatically shuffles through 54 custom watchfaces every 10 minutes, keeping power consumption ultra low while adding tons of personality.
15. LoRa Smart Bike Tracker
This project integrates the Seeed Studio WioTrackerL1, using Meshtastic long-range LoRa network to continuously monitor the bike’s location and provide anti-theft motion alerts, enhancing cycling safety. With just a simple setup, users can easily protect their bikes, showcasing the real-world potential of open hardware.
Miriam’s design is inspired by a keen observation of everyday needs, offering an innovative security solution while bringing open-source hardware closer to everyday tools.
That’s all for today, thank you all for reading through this September Monthly Wrap-up in your spare time. (It is indeed a fruitful month!) If you wanna share what projects you’re working on, shoot us a tweet @seeedstudio, let us know on LinkedIn and Discord, or publish your project on our Project Hub on Hackster.
#Notes
Previous Monthly Wrap-ups:
