Grove - Gas Sensor(MQ9)
Rating:
100% of 100
How to choose a gas sensor ? The Grove - Gas Sensor module is useful for gas leakage detecting(in home and industry)
$7.50
In stock
  • 10+: $6.75
  • 20+: $6.38
  • More
  • 50+: $6.00
  • Less
attention icon
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
The Grove - Gas Sensor module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, smoke and so on. Measurements can be taken as soon as possible based on its fast response time. Also, the sensitivity can be adjusted by the potentiometer.
Each Grove - Gas Sensor Kit consists of one gas sensor base and four detectors, including MQ2, MQ3MQ5and MQ9. Below is a contrast table of them. You can switch the detector on the base according to specific target gases.
Sysmbol MQ-2 MQ-3 MQ-5 MQ-9
Detect Gas
Combustible Gas, Smoke
Alcohol Vapor LPG, Natural Gas, Town Gas Carbon Monoxide, Coal Gas, Liquefied Gas
Concentration 300-10000ppm 0.04-4mg/L Alcohol 300-10000ppm 10-1000ppmCO;100-10000PPm Gas
attention icon
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
  • High sensitivity to Combustible gas in wide range
  • Stable performance, long life, low cost
  • Fast response
  • Wide detection range
  • Simple drive circuit
Dimensions 40mm x20mm x18mm
Weight G.W 17g
Battery Exclude
Grove - Gas Sensor(MQ9) 1
Grove Cable 1
ECCN 2B351
HSCODE 9027900000
USHSCODE 90230000
UPC 841454108320
ROHS 1
Wiki of Grove - Gas Sensor(MQ9)
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
Product Faqs
Sort by
