Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Vibrant Spectra™ 6 Technology Display: Showcase black, white, yellow, red, green and blue colors more than just black and white, resulting in striking visuals and clear information.
  • Ultra-Low Power Consumption: The ePaper consumes power only during updates, resulting in longer battery life and greater energy efficiency.
  • Plug&Play with XIAO ePaper Driver Board: Optimized for the XIAO ePaper Display Board EE02, powered by the XIAO ESP32-S3 Plus, featuring a reserved battery connector and user button to accelerate prototyping and project development.
  • Wide Range of Applications: Well-suited for applications such as electronic photo album, conference room signage, logistics tracking boards, and IoT dashboards, where high visibility, multi-color display, and low power consumption make a real impact.
Seamless Setup and Customization for Your ePaper Display
This ePaper display is designed to work seamlessly with any standard 60-pin driver board. We recommend the XIAO ePaper Display Board EE02, which will be available soon.
To make things even easier, we’re introducing SenseCraft HMI—a no-code, AI-powered platform that allows you to quickly design and customize your user interface. Drag and drop elements, choose templates, or let AI generate the perfect layout for you.Get started today and create your ideal display experience with ease!
How Spectra™ 6 works
Spectra displays are made of millions of Microcups® that suspend the particles in a clear fluid, enabling precise movement and stable color rendering. By combining red, yellow, green, and blue alongside monochrome, it achieves a rich six-color palette, delivering vivid images with paper-like readability.
Parameter
Type
Dot Matrix
Size
13.3 inch
Active Area(mm)
202.8 (H) x 270.4 (V)
Resolution
1200(H) x 1600(V)
Pixel Pitch(mm)
0.169 x 0.169
Display Color
Black, White, Yellow, Red, Green and Blue
Interface
SPI
Connector
60 Pin FPC, 0.5mm Pitch
Driver Mode
Support XIAO/Arduino/MicroPython
Drawing
Support GUI Drawing
Outline Dimension(mm)
208.8 (H) x 284.7 (V) x 0.85(D)
Weight(g)
50 ± 10
Hardware Overview
Application
  • Reading equipment
  • Retail shelf labels
  • Conference room signage
  • logistics tracking boards
  • Smart home dashboards
Certification
HSCODE8524999010
USHSCODE8524119000
UPC
EUHSCODE8471707000
COOCHINA
13.3-inch spectra™ 6 ePaper Display
×1
60Pin Adapter
×1
60Pin FFC Extension Cable
×1
13.3" spectra™ 6 E-Ink / ePaper Display with 1200x1600 Pixels, SPI interface, Support XIAO/Arduino
SKU 100088646
The 13.3 inch spectra™ 6 ePaper Display offer a high-quality, low-power solution for a wide range of applications. The model features a 1200x1600 resolution, black, white, yellow, red, green and blue display with a diagonal size of 13.3 inches. With a fast refresh rate and excellent contrast, this display is ideal for e-readers, smart wearables, and other portable devices.
USD$141.55
$149.00
Save $7.45(5%)
You may also add
