Arduino 板载外设
在第一篇 Arduino 入门与显示中,我们完成了 Arduino 环境配置和基础显示。本篇继续介绍 Sticky 的按键、蜂鸣器、温湿度传感器、IMU、电池和 MicroSD,并为每个外设提供可单独上传的例程。
选择 File > New Sketch,将当前实验的完整代码复制到新草图中,替换原有内容。上传会替换设备当前运行的程序。所需库和参考版本在各节中列出。
Tip
本篇示例通过 Serial1 输出运行结果。请选择 CH343P 对应端口,打开 Tools > Serial Monitor,并设为 115200 baud。如果错过启动时的输出,保持串口监视器打开,按下设备上的 RESET 复位键即可重新查看。
用户按键
本示例检测 AI / OK、UP、DOWN 三个按键的按下和松开,并在串口监视器中显示对应消息。无需安装额外库。
按键GPIO按下时的电平
AI / OKGPIO4LOW
UPGPIO5LOW
DOWNGPIO6LOW
新建草图,复制下方完整代码,点击 Verify,完成后点击 Upload。
 * reTerminal Sticky - Button Example
 * Reads the onboard AI / OK, UP, and DOWN buttons and prints their events.
#include <Arduino.h>
// CH343P UART connection: ESP32-S3 RX on GPIO44, TX on GPIO43.
constexpr int PIN_SERIAL_RX = 44;
constexpr int PIN_SERIAL_TX = 43;
// GPIO45 keeps the main power rail enabled.
constexpr int PIN_POWER_HOLD = 45;
// GPIO46 keeps the power controller locked on.
constexpr int PIN_POWER_LOCK = 46;
// AI / OK button on GPIO4, active LOW.
constexpr int PIN_BUTTON_AI = 4;
// UP button on GPIO5, active LOW.
constexpr int PIN_BUTTON_UP = 5;
// DOWN button on GPIO6, active LOW.
constexpr int PIN_BUTTON_DOWN = 6;
constexpr int BUTTON_PINS[] = {
  PIN_BUTTON_AI,
  PIN_BUTTON_UP,
  PIN_BUTTON_DOWN
const char* BUTTON_NAMES[] = {"AI / OK", "UP", "DOWN"};
constexpr int BUTTON_COUNT = 3;
constexpr unsigned long DEBOUNCE_MS = 30;
bool lastReading[BUTTON_COUNT];
bool stableState[BUTTON_COUNT];
unsigned long lastChange[BUTTON_COUNT];
void keepPowerOn() {
  pinMode(PIN_POWER_HOLD, OUTPUT);
  pinMode(PIN_POWER_LOCK, OUTPUT);
  digitalWrite(PIN_POWER_HOLD, HIGH);
  digitalWrite(PIN_POWER_LOCK, HIGH);
  keepPowerOn();
  Serial1.begin(115200, SERIAL_8N1, PIN_SERIAL_RX, PIN_SERIAL_TX);
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky Button Example");
  Serial1.println("Press AI / OK, UP, or DOWN to test.");
  for (int i = 0; i < BUTTON_COUNT; ++i) {
    pinMode(BUTTON_PINS[i], INPUT_PULLUP);
    lastReading[i] = digitalRead(BUTTON_PINS[i]);
    stableState[i] = lastReading[i];
    lastChange[i] = millis();
    const bool reading = digitalRead(BUTTON_PINS[i]);
    if (reading != lastReading[i]) {
      lastReading[i] = reading;
    // Report a change only after the input has remained stable.
    if (millis() - lastChange[i] >= DEBOUNCE_MS &&
        reading != stableState[i]) {
      stableState[i] = reading;
      Serial1.print(BUTTON_NAMES[i]);
      Serial1.println(reading == LOW ? " pressed" : " released");
  delay(5);
代码说明
  • INPUT_PULLUP 启用内部上拉,因此按键松开时读取为 HIGH,按下时为 LOW。
  • 程序通过 digitalRead() 读取按键,并使用 millis() 记录电平变化时间。输入连续稳定至少 30 ms,且与上一次确认的状态不同时,才输出按下或松开事件。
预期输出
打开串口监视器,依次短按三个按键,再按住其中一个约一秒后松开。每次按下和松开分别输出按键名称及 pressed、released。持续按住不会不断重复同一事件。
AI / OK pressed
AI / OK released
UP pressed
UP released
DOWN pressed
DOWN released
蜂鸣器控制
板载蜂鸣器连接到 GPIO48。本示例使用 Arduino 的 tone() 播放三种频率的短音,无需安装额外库。
将完整代码复制到新草图,编译并上传。
 * reTerminal Sticky - Buzzer Example
 * Plays three short tones at low, medium, and high frequencies.
// Onboard buzzer on GPIO48.
constexpr int PIN_BUZZER = 48;
void playTone(const char* name, unsigned int frequency) {
  Serial1.print("Playing ");
  Serial1.print(name);
  Serial1.print(" tone: ");
  Serial1.print(frequency);
  Serial1.println(" Hz");
  tone(PIN_BUZZER, frequency, 200);
  delay(250);  // Let the 200 ms tone finish before the next pitch.
  noTone(PIN_BUZZER);
  keepPowerOn();
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky Buzzer Example");
  Serial1.println("Playing three test tones...");
  playTone("low", 600);
  delay(150);
  playTone("medium", 900);
  delay(150);
  playTone("high", 1200);
  Serial1.println("Buzzer test complete");
代码说明
  • tone(PIN_BUZZER, frequency, 200) 设置蜂鸣器的频率和 200 ms 持续时间。修改 frequency 可以改变音高,noTone() 用于停止输出。
  • playTone() 先打印音调名称和频率,再播放短音。setup() 按顺序调用它播放三种音调,loop() 不重复调用。
预期输出
打开串口监视器,听取三声短音,同时查看音调频率和播放完成提示。依次播放的频率为 600、900、1200 Hz,每声约 200 ms,播放完成后输出 Buzzer test complete。
Playing low tone: 600 Hz
Playing medium tone: 900 Hz
Playing high tone: 1200 Hz
本示例只在启动时播放一次,不会循环播放。
温湿度读取
Sticky 配备板载 SHT40 温湿度传感器。本示例读取温度和相对湿度,并通过串口输出。
项目配置
I2C SDA / SCLGPIO1 / GPIO0
I2C 时钟频率400 kHz
SHT40 地址0x44
SHT40、IMU 和电量计共用这组 I2C 引脚,通过不同地址访问。
Step 1. 打开 Library Manager,搜索并安装 Sensirion 的 Sensirion I2C SHT4x,同时安装依赖库 Sensirion Core。参考版本分别为 1.1.2、0.7.3。
Step 2. 将下面的完整代码复制到新草图,编译并上传。
 * reTerminal Sticky - SHT40 Example
 * Reads temperature and relative humidity from the onboard SHT40 sensor.
#include <Wire.h>
#include <SensirionCore.h>
#include <SensirionI2cSht4x.h>
// CH343P UART: ESP32-S3 RX on GPIO44, TX on GPIO43.
// Main power hold and power lock signals, both active HIGH.
// Onboard sensor I2C bus: GPIO1 -> SDA, GPIO0 -> SCL.
constexpr int PIN_I2C_SDA = 1;
constexpr int PIN_I2C_SCL = 0;
constexpr uint32_t I2C_FREQUENCY = 400000;
// Onboard SHT40 I2C address.
constexpr uint8_t SHT40_ADDRESS = 0x44;
SensirionI2cSht4x sht40;
  keepPowerOn();
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky SHT40 Example");
  Wire.begin(PIN_I2C_SDA, PIN_I2C_SCL, I2C_FREQUENCY);
  sht40.begin(Wire, SHT40_ADDRESS);
  Serial1.println("Reading temperature and humidity every 5 seconds...");
  float temperature = 0.0f;
  float humidity = 0.0f;
  const uint16_t error = sht40.measureHighPrecision(temperature, humidity);
  // The library returns a status code separately from the measured values.
  if (error != 0) {
    char errorMessage[64];
    errorToString(error, errorMessage, sizeof(errorMessage));
    Serial1.print("SHT40 read failed: ");
    Serial1.println(errorMessage);
  } else {
    Serial1.print("Temperature: ");
    Serial1.print(temperature, 2);
    Serial1.print(" C, Humidity: ");
    Serial1.print(humidity, 2);
    Serial1.println(" %RH");
  delay(5000);
代码说明
  • Wire.begin() 配置 I2C 引脚和时钟,sht40.begin(Wire, SHT40_ADDRESS) 指定 SHT40 使用的总线和地址。
  • measureHighPrecision(temperature, humidity) 将温度和相对湿度写入两个变量,并返回状态码。返回 0 时输出读数;读取失败时,通过 errorToString() 将错误码转换为可读信息。
预期输出
打开串口监视器,观察至少两次读数。温度和相对湿度约每 5 秒输出一次,格式如下。实际读数随环境变化。
Temperature: 27.43 C, Humidity: 59.38 %RH
Temperature: 27.44 C, Humidity: 59.35 %RH
若运行时出现 SHT40 read failed,请确认 I2C 引脚和地址与上表一致,并查看串口输出的错误信息。
IMU 数据读取
板载 LSM6DS3TR-C 可测量三轴加速度和角速度。本示例演示如何读取这些数据,并观察设备移动时的变化。
项目配置
I2C 时钟频率400 kHz
LSM6DS3TR-C 地址0x6A
Step 1. 在 Library Manager 安装 Seeed Studio 的 Seeed Arduino LSM6DS3(参考版本 2.0.7)。
 * reTerminal Sticky - IMU Example
 * Reads acceleration and angular velocity from the onboard LSM6DS3TR-C IMU.
#include <Wire.h>
#include <LSM6DS3.h>
// Onboard LSM6DS3TR-C I2C address.
constexpr uint8_t IMU_ADDRESS = 0x6A;
LSM6DS3 imu(I2C_MODE, IMU_ADDRESS);
  keepPowerOn();
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky IMU Example");
  if (imu.begin() != 0) {  // Seeed's begin() returns 0 on success.
    Serial1.println("LSM6DS3TR-C initialization failed");
    Serial1.println("Check the I2C connection and reset the device.");
    while (true) {
  Serial1.println("Move or rotate the device to change the readings.");
  Serial1.print("Accel (g) X: ");
  Serial1.print(imu.readFloatAccelX(), 3);
  Serial1.print("  Y: ");
  Serial1.print(imu.readFloatAccelY(), 3);
  Serial1.print("  Z: ");
  Serial1.println(imu.readFloatAccelZ(), 3);
  Serial1.print("Gyro (dps) X: ");
  Serial1.print(imu.readFloatGyroX(), 2);
  Serial1.print(imu.readFloatGyroY(), 2);
  Serial1.println(imu.readFloatGyroZ(), 2);
  Serial1.println();
代码说明
  • LSM6DS3 imu(I2C_MODE, IMU_ADDRESS) 选择 I2C 接口和设备地址。初始化总线后,调用 imu.begin() 启动传感器;当前 Seeed 库以返回 0 表示成功,失败时本示例停止继续读取。
  • readFloatAccelX() 和 readFloatGyroX() 分别读取 X 轴加速度和角速度,Y、Z 轴使用对应函数。
预期输出
打开串口监视器,先将设备平放观察一组输出,再缓慢倾斜和转动,对比各轴读数。加速度和角速度约每秒输出一组。
Accel (g) X: -0.023  Y: 0.005  Z: 1.044
Gyro (dps) X: 1.89  Y: -3.85  Z: 0.07
加速度读数包含重力分量,因此设备静止时,三个轴的读数不会全部为零。
Tip
如果提示初始化失败,请核对 I2C 引脚和地址是否与上表一致。编译时缺少 LSM6DS3.h,请安装上述 Seeed Arduino LSM6DS3 库。
电池状态读取
本示例读取 BQ27220 电量计,显示电池电量、电压、电流和外部供电状态。所需的 Wire 随 ESP32 开发板包提供。
接口或信号配置
I2C SDA / SCLGPIO1 / GPIO0,400 kHz
BQ27220 地址0x55
充电使能GPIO39,LOW 使能
外部电源检测GPIO9,HIGH 表示有外部供电
Step 1. 保持 USB 连接,将完整代码复制到新草图,编译并上传。
展开完整代码
 * reTerminal Sticky - Battery Example
 * Prints battery percentage, voltage, current, and charging status.
#include <Wire.h>
// GPIO39 -> EN_BAT_CHGn, charger enable, active LOW.
constexpr int PIN_BATTERY_CHARGE_ENABLE = 39;
// GPIO9 -> USB/external power detection, HIGH when power is present.
constexpr int PIN_EXTERNAL_POWER = 9;
// Onboard BQ27220 fuel-gauge address and standard-command registers.
constexpr uint8_t BQ27220_ADDRESS = 0x55;
constexpr uint8_t REG_VOLTAGE = 0x08;
constexpr uint8_t REG_CURRENT = 0x0C;
constexpr uint8_t REG_STATE_OF_CHARGE = 0x2C;
// BQ27220's default current scale is based on a 10 mOhm sense resistor.
// Sticky uses a 100 mOhm sense resistor (R46), so apply the resistor ratio.
constexpr int BQ27220_DEFAULT_SENSE_RESISTOR_MILLIOHMS = 10;
constexpr int STICKY_SENSE_RESISTOR_MILLIOHMS = 100;
void initializeCharger() {
  pinMode(PIN_BATTERY_CHARGE_ENABLE, OUTPUT);
  digitalWrite(PIN_BATTERY_CHARGE_ENABLE, LOW);
  pinMode(PIN_EXTERNAL_POWER, INPUT);
bool readBQ27220Word(uint8_t registerAddress, uint16_t& value) {
  Wire.beginTransmission(BQ27220_ADDRESS);
  Wire.write(registerAddress);
  if (Wire.endTransmission(false) != 0) {  // Repeated start for the read.
    return false;
  if (Wire.requestFrom(BQ27220_ADDRESS, static_cast<uint8_t>(2)) != 2) {
    return false;
  const uint8_t lowByte = Wire.read();
  const uint8_t highByte = Wire.read();
  value = static_cast<uint16_t>(lowByte) |
          (static_cast<uint16_t>(highByte) << 8);
  return true;
bool readBQ27220CurrentMilliamps(int16_t& currentMilliamps) {
  uint16_t raw = 0;
  if (!readBQ27220Word(REG_CURRENT, raw)) {
    return false;
  const int16_t gaugeCurrent = static_cast<int16_t>(raw);  // Keep the sign.
  const int32_t scaledCurrent =
      static_cast<int32_t>(gaugeCurrent) *
      BQ27220_DEFAULT_SENSE_RESISTOR_MILLIOHMS /
      STICKY_SENSE_RESISTOR_MILLIOHMS;
  currentMilliamps = static_cast<int16_t>(scaledCurrent);
  return true;
  keepPowerOn();
  initializeCharger();
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky Battery Example");
  Serial1.println("Reading battery data and charging status every 2 seconds...");
  uint16_t stateOfCharge = 0;
  uint16_t voltage = 0;
  int16_t current = 0;
  const bool readOk =
      readBQ27220Word(REG_STATE_OF_CHARGE, stateOfCharge) &&
      readBQ27220Word(REG_VOLTAGE, voltage) &&
      readBQ27220CurrentMilliamps(current);
  if (!readOk) {
    Serial1.println("BQ27220 read failed. Check the I2C connection.");
  } else {
    if (stateOfCharge > 100) {
      stateOfCharge = 100;
    const bool charging = digitalRead(PIN_EXTERNAL_POWER) == HIGH;  // USB power present.
    Serial1.print("Battery: ");
    Serial1.print(stateOfCharge);
    Serial1.print(" %, Voltage: ");
    Serial1.print(voltage);
    Serial1.print(" mV, Current: ");
    Serial1.print(current);
    Serial1.print(" mA, Charging: ");
    Serial1.println(charging ? "YES" : "NO");
  delay(2000);
代码说明
  • readBQ27220Word() 从指定寄存器读取两个字节,并按低字节在前的顺序组合为一个 16 位数值。程序使用它读取电量、电压和原始电流;读取失败时返回 false。
  • readBQ27220CurrentMilliamps() 将原始电流按有符号数处理,再根据芯片默认的 10 mΩ 与 Sticky 板载 100 mΩ 采样电阻之比进行换算。复用时请保留这项换算和电流正负号。
  • initializeCharger() 将 GPIO39 拉低以使能充电功能。
预期输出
打开串口监视器,等待至少两秒,查看 Battery、Voltage、Current 和 Charging。电量、电压、电流和外部供电状态约每 2 秒输出一次,数值随电池和供电状态变化。
Battery: 61 %, Voltage: 3801 mV, Current: 512 mA, Charging: YES
Battery: 61 %, Voltage: 3803 mV, Current: 571 mA, Charging: YES
Charging 表示 GPIO9 检测到的外部供电状态。YES 说明 USB/外部电源已连接。
Tip
若出现 BQ27220 read failed,表示本次 I2C 读取失败。请核对 I2C 引脚和地址是否与上表一致。
使用 MicroSD 卡
本示例读取 MicroSD 卡容量,并列出根目录中的文件和文件夹。所需的 SPI、FS、SD 均随 ESP32 开发板包提供。
信号GPIO说明
SPI SCKGPIO13时钟
SPI MISOGPIO12数据输入
SPI MOSIGPIO14数据输出
SD CSGPIO8卡片片选,LOW 有效
SD 电源使能GPIO10HIGH 开启供电
SD 卡检测GPIO11LOW 表示已插卡
屏幕 CSGPIO15访问 SD 时保持 HIGH
Step 1. 准备一张 FAT32 格式的 microSD 卡,建议使用 MBR(Master Boot Record)分区表。在根目录放入一些文件和文件夹,再将卡插入 Sticky。
Step 2. 将完整代码复制到新草图,编译并上传。
展开完整代码
 * reTerminal Sticky - MicroSD Example
 * Initializes the onboard microSD card and lists its root-directory contents.
#include <SPI.h>
#include <FS.h>
#include <SD.h>
// The microSD card shares this SPI bus with the ePaper display.
constexpr int PIN_SPI_SCK = 13;
constexpr int PIN_SPI_MISO = 12;
constexpr int PIN_SPI_MOSI = 14;
constexpr int PIN_SD_CS = 8;
constexpr int PIN_SD_ENABLE = 10;  // microSD power enable, active HIGH.
constexpr int PIN_SD_DETECT = 11;  // card detect, active LOW.
constexpr int PIN_EPD_CS = 15;
SPIClass sdSpi(FSPI);  // This standalone sketch does not start the display.
void listRootDirectory() {
  File root = SD.open("/");
  if (!root || !root.isDirectory()) {
    Serial1.println("Unable to open the root directory");
    if (root) {
      root.close();
    return;
  Serial1.println("Root directory:");
  int entryCount = 0;
  File entry = root.openNextFile();
  while (entry) {
    if (entry.isDirectory()) {
      Serial1.print("[DIR]  ");
      Serial1.println(entry.name());
    } else {
      Serial1.print("[FILE] ");
      Serial1.print(entry.name());
      Serial1.print("  ");
      Serial1.print(entry.size());
      Serial1.println(" bytes");
    ++entryCount;
    entry.close();
  if (entryCount == 0) {
    Serial1.println("(empty)");
  root.close();
  keepPowerOn();
  delay(200);
  Serial1.println();
  Serial1.println("reTerminal Sticky MicroSD Example");
  // Keep the ePaper device deselected while the shared bus is used by SD.
  pinMode(PIN_EPD_CS, OUTPUT);
  digitalWrite(PIN_EPD_CS, HIGH);  // HIGH deselects the shared-SPI display.
  pinMode(PIN_SD_CS, OUTPUT);
  digitalWrite(PIN_SD_CS, HIGH);
  // Power-cycle the card while both devices remain deselected from the
  // shared SPI bus.
  pinMode(PIN_SD_ENABLE, OUTPUT);
  digitalWrite(PIN_SD_ENABLE, LOW);
  pinMode(PIN_SD_DETECT, INPUT_PULLUP);
  if (digitalRead(PIN_SD_DETECT) == HIGH) {
    Serial1.println("No microSD card detected");
    return;
  digitalWrite(PIN_SD_ENABLE, HIGH);
  delay(100);
  sdSpi.begin(PIN_SPI_SCK, PIN_SPI_MISO, PIN_SPI_MOSI, PIN_SD_CS);
  if (!SD.begin(PIN_SD_CS, sdSpi)) {
    Serial1.println("MicroSD initialization failed");
    Serial1.println("Check the card format and partition scheme.");
    return;
  Serial1.print("Card size: ");
  Serial1.print(SD.cardSize() / (1024ULL * 1024ULL));
  Serial1.println(" MB");
  listRootDirectory();
代码说明
  • SD 卡与屏幕共享 SPI 线路。本示例不启动显示驱动,使用 SPIClass sdSpi(FSPI) 创建 SPI 实例,并将屏幕 CS 拉高,使屏幕不响应 SD 通信。
  • 检测到插卡后,程序开启卡槽供电并等待 100 ms,再调用 sdSpi.begin() 配置 SPI 引脚,通过 SD.begin(PIN_SD_CS, sdSpi) 初始化卡片。
  • SD.open("/") 打开根目录,openNextFile() 用于依次读取其中的文件和文件夹。
预期输出
打开串口监视器。初始化成功后,串口会显示卡容量和根目录中的项目,请确认列表中包含事先放入的文件。
Card size: 60906 MB
Root directory:
[DIR]  System Volume Information
[DIR]  logs
[DIR]  reterminal
[FILE] page.jpg  97043 bytes
[FILE] index.md  8032 bytes
[DIR] 表示文件夹,[FILE] 表示文件。实际项目和显示顺序取决于卡内内容;根目录为空时会显示 (empty)。
本示例仅在启动时读取一次根目录。更改卡内文件后,需重新运行示例才能查看更新后的列表。
常见问题
现象处理方法
没有串口输出确认选择 CH343P 对应端口,并将波特率设为 115200。本篇示例使用 Serial1 输出日志。
缺少传感器头文件按小节的完整名称安装库,SHT4x 同时需要 Sensirion Core
下一步
继续阅读 Arduino 交互与低功耗,学习触摸、时间、声音采集和按键唤醒,再尝试综合 Demo。
Community 社区支持
Need more help? 还需要帮助?
Join our community, ask questions, or reach out to Seeed Studio technical support. 加入社区提问交流,或直接联系 Seeed Studio 技术支持。
