Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • IP68 Rating
  • Anti-UV and Anti-Rain
  • Suitable for long-term outdoor use
Cable Parameters
Details
Parameters
Connector Type
Aviation Connector
Number of Pins
5 Pins
Protection Rating
IP68
Signal Type
RS485
Cable
Cable Standard
UL2464
Core Structure
5 Cores
Conductor
Tinned Copper
Outer Diameter
Approx. 5.0 mm
Jacket Color
Black
Electrical
Rated Voltage
300 V
Insulation Resistance
≥ 20 MΩ
Withstand Voltage
AC 300 V / DC 300 V
Conductor Resistance
≤ 3 Ω
Mechanical
Cable Length
5 m
Soldered
Environment
Operating Temperature
-40°C to +85°C
Application Environment
Outdoor / Industrial
Hardware Overview
P1
Color
P2
1
Blue
Power Supply (12V+)
1
2
Red
Power Ground (5V-)
2
3
Yellow
RS485-A
3
4
Green
RS485-B
4
5
Black
GND
5
Application
  • RS485-based sensors and devices
  • Extending connections for SenseCAP Sensor Hub and other MODBUS RS485 systems
  • Industrial automation and fieldbus networks
  • Outdoor sensor networks in harsh weather conditions
  • Robotics and motion control systems
  • Industrial data acquisition, monitoring, and environmental sensing
Certification
HSCODE8544422900
USHSCODE8544421000
UPC
EUHSCODE8544119000
COOCHINA
Item
Quantity
RS485 5-Pin Aviation Connector Extension Cable (Male + Female)
x1
5-Meter RS485 Extension Cable for Sensor Hub
SKU 321990796
This RS485 Extension Cable is an industrial-grade solution designed to extend the connection of SenseCAP Sensor Hub to individual sensors. It features an IP68 rating, comes with a waterproof aviation connector, and is easy to use, making it suitable for a variety of industrial and outdoor applications.
USD$9.90
You may also add
