Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Global solar radiation
Sunshine Duration
Light Intensity
Rainfall Intensity
S700
Optical
S700-C
Radar
S700-B
Optical
S700-A
Radar
Comprehensive 7-parameter Measurement
The S700-C is equipped with multiple sensors measuring crucial parameters for gathering a wealth of environmental data, including air temperature, relative humidity, barometric pressure, total solar radiation, sunshine duration, rain intensity (Radar Rainfall), wind speed and wind direction.
Industrial-level Design
Wide operating temperature range from -40°C to +85°C and High Protection Rating of IP66
Versatile Output Interface
The S700-C offers 2 common and reliable output interfaces, namely RS485 (supports MODBUS-RTU protocol) and SDI-12.
Thermostatically-controlled Heating System
This heating system is thermostatically controlled, ensuring that the device can maintain its normal working state and accurate measurement capabilities at extremely cold temperatures.
Powerful Components
  • Long Cable for Mounting: A 3-meter cable is provided for pole mounting,
  • Accuracy-enhancing Shields: Radiation shields are equipped which minimize the impact of external factors on the sensor's readings.
  • Advanced Wind Sensors: It uses ultrasonic wind speed and direction sensors without movable components. This design with bird-proof structure not only reduces the risk of mechanical wear and tear but also improves the durability and accuracy of wind measurement.
Reliable and High Standard Test Performance
Parameter
Measurement parameters
Air temperature(℃)
Air humidity(%)
Barometric pressure(Pa)
Global solar radiation(W/m²)
Sunshine duration(h)
Rain intensity-Radar rainfall(mm/h)
Wind speed(m/s)
Wind direction (°)
Interface
M12 connector
Communication Protocol
RS485(Modbus-RTU)/SDI-12/ASCII
Power Supply
12V~24V
24V (Heating power supply)
Power Consumption
0.6W (heating 21W)
Cable Length
3m
Ambient Condition
IP Rating
IP66
Operation Temperature
-40°C ~ + 85 °C
Humidity
0 ~ 100%RH (no condensation)
Mechanical
Dimension
140x140x350mm
Weight
1607g
Technical Parameters
Principle
Range
Respond Time
Resolution
Response spectrum
Accuracy
Annual Drift
Stability Time
Air temperature(℃)
-40 °C ~ +85 °C
0.01 ℃
± 0.1℃
Relative humidity(%)
0 ~ 100% RH
0.01% RH
± 1.5% RH
Barometric pressure (Pa)
300 ~ 1250 hPa
10 Pa
± 50 Pa
Rain intensity (mm/h)
Radar
0 ~ 300 mm/h
0.01 mm/h
± 10%
Wind speed (m/s)
Ultrasonic
0~60 m/s standard range
0~75m/s extended range
Up to 80m/s withstand range
0.1 m/s
±0.3m/s(≤10m/s);
±3% (10m/s ~ 50m/s)
±5% (>50m/s)
Wind direction (°)
Ultrasonic
0 ~ 360 °
0.1°
± 3.0°
Global solar radiation (W/m²)
photoelectric
0~2000 W/m²
<=1S
1 W/m²
300~1100nm
±3%
less than 3%
<=1S
Sunshine duration (h)
photoelectric
0~6553.5 h
<=100ms
0.1 h
300~1100nm
±3%
less than 3%
<=1S
Hardware Overview
Wire Connection
The equipment uses M12 connectors with an 8-core specification. Cables in 8 different colors are used to supply power to the equipment and for data communication.
The bottom wire outlet is 3m. There is a six-core wire cable, including wires in colors of white, brown, green, yellow, gray, pink, blue and red.
The SenseCAP ONE series supports connection to various data acquisition devices, Programmable Logic Controllers (PLCs) or Host Computers via RS485, ASCII and SDI-12 protocols.
SenseCAP ONE Series Comparison
Application
  • Backyard and Garden: Measure air temperature and humidity, Rainfall Intensity, UV index, etc. in the backyard and garden to protect your family.
  • Smart Agriculture: Enable farmers to obtain climate data and information in time, take scientific management measures into production, and improve agricultural production capacity and level.
  • Meteorology: Support applications in the professional meteorological field, for example, timely reflect the changes of various abnormal meteorological conditions in the field of traffic and transportation to provide real-time scientific basis data for traffic management departments.
  • Urban Weather: Provide real-time data for urban squares, parks, scenic spots, golf courses, and other urban areas.
  • Transportation and Traffic: Supplies real-time local weather measurements for roads, transport facilities, and traffic management systems operating under changing outdoor conditions.
Certification
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
component name
quantity
SenseCAP S700-C 7-in-1 Compact Weather Station
x 1
M12 8-pin communication cable
x 1
USB Type-C cable
x 1
Screw
x 6
Flat washer
x 1
SenseCAP S700-C 7-in-1 Compact Weather Station (Solar Radiation & Radar Rain)
SKU 101991141
S700-C 7-in-1 Compact Weather Sensor with pyranometer measures air temperature, relative humidity, barometric pressure, global solar radiation, sunshine duration, rain intensity (radar), wind speed, and wind direction. It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
As a compact agriculture weather station, the S700-C provides localized weather and solar radiation data in multiple agricultural environments.
Use it with SenseCAP LoRaWAN Data Logger or SenseCAP 4G Data Logger.
USD$799.00
You may also add
