Product Details
Wiki & Learn
Reviews
Download PDF
Feature
What is the difference between S700, S700-B and S700-A?
Global solar radiation
Sunshine Duration
Light Intensity
Rainfall Intensity
S700
Optical
S700-C
Radar
S700-B
Optical
S700-A
Radar
  • 7 parameters measurement: Measures air temperature, relative humidity, barometric pressure, light intensity, precipitation intensity(radar), wind speed, and wind direction in 1 single sensor
  • Industrial-level design: -40°C to +85°C operating temperature, IP66 rated: waterproof, and dustproof, suitable for outdoor scenarios
  • Output interface: RS485 (MODBUS-RTU) / SDI-12
  • Thermostatically-controlled heating system: Independent heating power supply for use in extremely cold environments
  • Powerful Components Included: A 3m cable for the pole mount; radiation shields are equipped to ensure accurate ambient measurement; ultrasonic wind speed & direction sensors without moving parts
  • High-performance Guarantee
  • Radar rainfall monitoring: Utilizes electromagnetic wave scattering analysis to measure precipitation intensity. It has a larger measuring range and higher accuracy, making it suitable for large-scale precipitation monitoring.
We are well aware that the sensors may work under harsh outdoor conditions. To ensure that the performance and durability of the sensors are consistent with their specifications throughout the complete lifecycle, SenseCAP ONE Serials Sensor went through 6 reliability tests before releasing and met the requirements to perform perfectly in extreme conditions.
  • Wind tunnel for wind calibration
  • High-Low Temperature Test - determine performance under adverse temperature conditions.
  • Structural Test - whether the collected values of multiple devices are consistent
  • x-y-z vibration test
  • Waterproof and air tightness test
  • R&D and Production Test - to test the pass rate of multiple devices under factory conditions
General Parameters
Parameters Measured
air temperature, relative humidity, barometric pressure, wind speed, wind direction,rainfall intensity(radar) and light intensity
Protocol
Power Supply
12V~24V
24V(Heating power supply)
Cable Length
3m
Operating Temperature & Humidity
-40 °C ~ + 85 °C, 0 ~ 100%RH
IP Rating
IP66
Device Weight
2kg
Air Temperature
Range
- 40 °C ~ + 85 °C
Accuracy
± 0.1℃
Resolution
0.01 ℃
Air Humidity
Range
0 ~ 100% RH
Accuracy
± 1.5% RH
Resolution
0.01% RH
Barometric Pressure
Range
300 ~ 1250 hPa
Accuracy
± 50 Pa
Resolution
10 Pa
Wind Speed (Ultrasonic)
Range
0~60 m/s standard range
0~75m/s extended range
Up to 80m/s withstand range
Accuracy
±0.3m/s(≤10m/s);
±3% (10m/s ~ 50m/s)
±5% (>50m/s)
Resolution
0.1 m/s
Wind Direction (Ultrasonic)
Range
0 ~ 360 °
Accuracy
± 3.0°
Resolution
0.1°
Rainfall Intensity (Radar)
Range
0 ~ 300 mm/h
Accuracy
± 10%(Generally high precision)
Resolution
0.01 mm/h
Light Intensity
Range
0 ~ 200,000 Lux
Accuracy
± 5% of reading
Resolution
5 Lux
Hardware Overview
Application
  • Backyard and Garden: Measure air temperature and humidity, Rainfall Intensity, UV index, etc. in the backyard and garden to protect your family.
  • Smart Agriculture: Enable farmers to obtain climate data and information in time, take scientific management measures into production, and improve agricultural production capacity and level.
  • Meteorology: Support applications in the professional meteorological field, for example, timely reflect the changes of various abnormal meteorological conditions in the field of traffic and transportation to provide real-time scientific basis data for traffic management departments.
  • Urban Weather: Provide real-time data for urban squares, parks, scenic spots, golf courses, and other urban areas.
  • Transportation and Traffic: Supplies real-time local weather measurements for roads, transport facilities, and traffic management systems operating under changing outdoor conditions.
Today, data on localized weather, known as microclimates, is the new frontier for more precise and accurate weather forecasting. As a result, the collection of weather data is becoming increasingly smaller and gridded. In light of this, weather sensors, which are the most convenient means of collecting weather data, are seeing a rise in demand.
SenseCAP ONE is a series of all-in-one compact weather sensors, that integrate multiple sensors into this compact device, monitoring up to 10 weather parameters: air temperature, air humidity, atmospheric pressure, light intensity, wind speed, wind direction, precipitation, PM 2.5, PM 10, and CO2.
The SenseCAP ONE series uses the RS485 (MODBUS-RTU) / SDI-12 communication protocol. Hence, the SenseCAP ONE compact weather sensor can be used with any data logger that supports RS485 (MODBUS-RTU) / SDI-12.
We offer the SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio and Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
Certification
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
SenseCAP S700-A 7-in-1 Compact Weather Station-Radar Rain
SKU 101991050
S700 7-in-1 Compact Weather Sensor measures air temperature, relative humidity, barometric pressure, light intensity, rainfall (radar), wind speed, and wind direction (ultrasonic). It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
Use it with SenseCAP LoRaWAN Data Logger or SenseCAP 4G Data Logger.
USD$759.00
