Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
  • Options marked with * require additional purchase according to the bundle.
  • For 4G functionality, both a 4G module and a 4G antenna must be selected.
  • For GPS functionality, both a 4G module and a GPS antenna must be selected.
  • For LoRaWAN® functionality, LoRaWAN® module must be selected.
  • Price Increase Announcement
    Date: March 2, 2026
    Due to increased demand for modules and SSDs, reComputer' pricing is expected to rise by approximately $20–$80 in the coming weeks. Please confirm your orders and requirements accordingly to help secure availability.
  • Powerful Performance with Raspberry Pi CM5: Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz. Features up to 16GB RAM and 32GB eMMC.
  • Robust Heat Dissipation: High-performance fanless cooling, engineered to handle the intense heat of AI workloads and ensure stable operation from -20°C to 65°C.
  • Industrial-Grade Reliability: High Accuracy RTC, hardware watchdog and optional UPS supercapacitor. Optional TPM/ATECC608A. IP40, aluminum alloy enclosure provides industrial-grade protection. Supports DIN-rail and wall mounting. Guaranteed production until at least December 2036.
  • AI-Optimized Computing: With the optional Hailo-8 AI accelerator, it delivers up to 26 TOPS, enabling real-time, high-performance AI vision processing across multiple channels.
  • Rich Industrial Connectivity: 3x RS485, 1x RS232, 8x DI, 8x DO, all isolated. 1x 10M/100M/1000M Ethernet (PoE), 1x 10M/100M Ethernet. 2x HDMI 2.0. 3x Type-A USB3.0, 1x Type-A USB2.0, 1x Type-C USB2.0 (for OS update). 1x Nano SIM card slot.
  • Versatile Wireless Connectivity: On chip Wi-Fi and BLE. Flexible expansion via Mini-PCIe for LTE, LoRa®, Zigbee. M.2 B-Key for 4G/5G.
Seeed Studio Tutorial of Al Kit with Raspberry Pi: From Zero to Hero
This course is designed to teach you how to harness the power of AI on the Raspberry Pi, with a focus on using an AI kit to perform computer vision tasks. You'll learn how to integrate AI into real-world IoT applications, from object detection and image classification to more complex visual recognition tasks.
We will guide you step-by-step through setting up your Raspberry Pi, using AI frameworks, and deploying these models in various practical scenarios.
Note: The first 200 units of each reComputer Industrial R SKU on this bundle page are NPI production units and currently do not support UPS functionality. UPS support will be added in subsequent mass production units. If UPS functionality is required, please contact Customer Service.
Hardware Specification
Product Series
R20xx-12
R20xx-10
CPU
Raspberry Pi Compute Module 5, 2.4GHz quad-core 64-bit Arm Cortex-A76
AI Processor
1x Pre-installed Hailo-8 M.2 AI Acceleration, 26TOPS
Operating System
Raspbian, Debian
Memory & Storage
2GB/4GB/8GB/16GB RAM, 16GB/32GB/64GB eMMC
System Specification
Power Input
DC 9V~36V, 2-pin Terminal Block
PoE(as powered device)
IEEE 802.3 at Standard 25.5W PoE
Power Switch
No
Reboot Switch
Yes
Interface
Ethernet & USB
1x 10/100/1000 Mbps(supports PoE PD); 1x 10/100 Mbps IEEE 802.3/802.3u
3x USB-A 3.0 Host; 1x USB-A 2.0 Host; 1x USB-C 2.0 (For flashing OS & Debug)
COM and I/O
3x RS485(Isolated); 1x RS232(Isolated)
8x DI Ports(Isolated), input Voltage: 5~24V DC; 8x DO Ports(Isolated), output Voltage: <60V DC
SIM Card
1x Nano SIM Card Slot
M.2 Slot
1x M.2 M-key 2280 Slot for NVMe SSD;
1x M.2 M-key 2280 Slot for AI Accelerator
(pre-installed Hailo-8 M.2 AI Acceleration 26TOPS);
1x M.2 B-key 3042/3052 Slot for 5G/4G LTE
1x M.2 M-key 2280 Slot for AI Accelerator;
Mini-PCIe
1x Mini-PCIe for LoRa module
Control & Indication
4x LEDs; 1x Buzzer; 1x Reset Button
HDMI
2 x HDMI 2.0
Wireless Communication
Wi-Fi 2.4/5.0 GHz(On-chip); BLE 5.0(On-chip);
USB LoRa®*/SPI LoRa®*
4G LTE/5G*
USB Zigbee*
Standards
EMC
ESD: EN61000-4-2, Level 3; EFT: EN61000-4-4, Level 2; Surge: EN61000-4-5, Level 2
Certification
CE, FCC, TELEC, RoHS, REACH
Device Specification
Ingress Protection
IP40
Temperature
Operating Temperature -20~65°C
Storage Temperature -40~85°C
Operating Humidity
10~95% RH
Reliability
SuperCAP UPS LTC3350 Module*
Hardware Watchdog: 1~255s
High Accuracy RTC
Security
Encryption Chip TPM 2.0*
ATECC608A*
Heat Dissipation
Fanless
Warranty
2 years
Production Lifetime
Until December 2036
Dimension(W x H x D) & Weight(Net)
197.5 mm x 155 mm x 67.5 mm, 1280g
Enclosure
6063 aluminum alloy heat sink, 5052 aluminum alloy enclosure
Mounting
DIN-rail/Wall
Statement
Hardware Overview
Application
With advanced features like object detection, object recognition, object tracking, OCR, and abnormal event detection with real-time alert triggers, this industrial-grade edge AI/IOT controller is designed to deliver exceptional performance in resource-constrained environments.
  • Manufacturing & Industrial Automation
With rich industrial interfaces, the controller integrates seamlessly with different sensors, PLCs, and machinery, enabling efficient process monitoring and control. It supports multiple communication protocols for real-time data acquisition and remote equipment management, fostering a smarter and more efficient factory.
  • AI-Powered Video Analytics & Surveillance
Integrated into NVR systems for real-time video analytics, including anomaly detection, object detection, crowd monitoring and behavior analysis, enhancing situational awareness and security efficiency.
  • Smart Transportation
Acts as an AI/IoT gateway for real-time processing of visual data from multiple sensors and camera feeds at the edge, enabling intelligent traffic flow analysis and smart parking management to enhance transportation monitoring management capabilities.
  • Smart Building
Integrates sensors and IoT devices to monitor and optimize building systems such as lighting, HVAC, and security. Uses AI for energy efficiency, predictive maintenance, and occupant comfort, enhancing building management.
  • Smart Retail
Create innovative smart retail solutions using AI-driven features like real-time visual product recognition, personalized shopping experiences, and advanced customer behavior analytics for optimized store operations.
reComputer Industrial R20xx
x 1
Mounting Bracket
x 2
Bracket Screw
x 4
DIN-rail Clip
x 1
DC Power Female Jack to Screw Terminal Adapter
x 1
12V/3A Power Adapter (with 4 interchangeable adapter plugs)
x 1
15*2-pin Terminal Block Connector (Male)
x 1
120Ω Resistor
x 5
Wi-Fi/BLE Antenna
x 1
User Manual
x 1
reComputer Industrial R20 & Optional Accessories - The Most Reliable and Powerful Raspberry Pi Edge AI/IOT Controller
SKU E2025091901
Industrial-grade edge AI/IOT controller powered by Raspberry Pi CM5 with optional Hailo-8 AI acceleration (26 TOPS). Features 8GB/16GB RAM, 32GB eMMC, extensive industrial interfaces, versatile wireless options, fanless cooling, wide temperature range (-20°C to 65°C), and long-term production support. Engineered for dependable AI performance and seamless connectivity in demanding environments.
USD$599.50
reComputer Industrial R2035-12 - The Most Reliable and Powerful Raspberry Pi Edge AI/IOT Controller x1$599.50
You may also add
