Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Power Supply:  When driving all channels simultaneously, the total current may exceed the limit of a standard computer USB port (causing flickering or dimming). In this case, please connect a 3.7V Li-Po battery or use a 5V/2A USB wall adapter.
  • Adapted for 1mm 3V COB LED Strips: The kit provides a selection of 5 different types of flexible COB strips (1mm width) to suit various project needs. The onboard hardware current limiting is specifically tuned to match the electrical characteristics of these 3V strips, providing Makers with a safe, stable experience.
  • Strategic 7-Channel Hybrid Output: Efficiently manages your entire lighting setup with a single board. It features 3 High-Power Channels (300mA) for bright main lighting and 4 Dimmable Channels (80mA) for delicate breathing or fading effects. One board handles it all—keeping your main lights bright and your effects dynamic.
  • 1mm Ultra-Flexible & 360° Cool White: The kit features filaments crafted from flexible FPC and Silicone Phosphor, boasting an ultra-narrow 1mm width and delivering a 360° full-angle glow. They emit a crisp 6500K Cool White light with CRI >80, providing accurate color rendering and a continuous, dot-free linear aesthetic—far superior to traditional rigid LEDs.
  • Versatile Single & Double-Ended Designs: The kit supports two structural options to match your layout. Single-Ended strips allow for clean wiring in tight blind spots. Double-Ended strips feature conductive connectors on both ends to ensure uniform voltage distribution for consistent brightness.
 Driver Board Specification
Parameter
COB LED Power Support
DC 3V
Power Input
5V/1A USB (via XIAO)
Note: A 5V/2A+ wall adapter is recommended for full-load operation.
3.7V Li-Po Battery (via onboard Battery Port)
3x High-Power Ports
(Screw Terminals)
3 Channels Output
Drive Capability: Max 300mA/channel
Control Logic: 1x Always-On + 2x GPIO Switch(D0,D1)
Note: On/Off Switch Only, NO PWM Support
4x Low-Power Ports
(Bottom Pads)
4 Channels Output
Drive Capability: Max 80mA/channel
Control Logic: Fully Dimmable (PWM) via D2, D3, D8, D9
Note: Active LOW logic
Onboard
Grove I²C Connector x1
Power Switch x1
Power LED x1
Battery Connector x1
Supported XIAO
XIAO RP2040、XIAO RP2350、XIAO nRF52840、XIAO ESP32-C3/C6/S3、XIAO RA4M1、XIAO MG24
Dimensions
30mm*41mm*16mm(With a Seeed Studio XIAO)
COB LED Strip Specification
Product
Name
Length
Operating Current
Luminous Flux
Cut
Fit
Double Ended COB LED Strip - 38mm White 6500K(10PCS) | Flexible 3V Filament
38mm
100mA (Recommended)
>20 lm (@ 100mA)
No
130mm Flexible COB LED Filament (White) - High Brightness for Sabers & Neon
130mm
300mA (Recommended)
21-25 lm (@ 300mA)
No
300mm Flexible COB LED Filament (White) - High Brightness for Sabers & Neon
300mm
300mA (Recommended)
>50 lm (@ 300mA)
No
Single Ended Cuttable COB LED Strip - 110mm White | DIY Custom Length
110mm
100mA (Recommended)
>23 lm (@ 200mA)
Yes
Single Ended Cuttable COB LED Strip - 300mm White | DIY Custom Length
300mm
100mA (Recommended)
>22 lm (@ 100mA)
Yes
Hardware Overview
  • Top
  • Bottom
Application
  • 3D Printed Model Decoration
  • Creative Ambient Lighting
  • DIY Electronic Crafts
  • Model Kit Upgrades
COB LED DIY Kit for Seeed Studio XIAO
SKU E25121201
This is a customizable COB LED DIY Kit designed for Seeed Studio XIAO. The kit centers on a 7-channel expansion board that breaks GPIO power limits , specifically tailored for driving the included series of low-power, ultra-narrow 1mm 3V COB LED strips. With integrated PMIC battery management, it is the ideal plug-and-play solution for building compact, high-brightness wireless lighting setups.
USD$5.90
COB LED Driver Board for Seeed Studio XIAOx1$5.90
You may also add
