Home Assistant Sensors: Elevate Your Smart Home with the Right Choices
By Liyan Gong Last Updated on: August 14, 2025With the introduction of Home Assistant hub, setting up smart home automation has become more accessible than ever. Selecting the right sensors is essential to collect accurate data and automate various home systems.
This guide explores sensor types compatible with Home Assistant hub, offering automation ideas and real-world use cases. We’ll also cover how to integrate these sensors with Home Assistant hub, ensuring seamless operation whether through native support or additional setup with ESPHome.
Table of Contents
1. Temperature and Humidity Sensors
Monitoring temperature and humidity helps you automate climate control systems, ensuring your home stays comfortable and energy-efficient. Here are some top picks that work well with Home Assistant hub:
This sensor provides accurate readings of temperature and humidity, useful for automating HVAC systems or dehumidifiers. While not natively supported, it can be integrated with Home Assistant using ESPHome via I2C.
A more budget-friendly sensor for temperature and humidity. Although basic, it serves well for simple climate monitoring in home spaces, integrated via ESPHome.
Perfect for harsher environments such as basements or garages. Integration is similar to the DHT20 and requires using ESPHome or MQTT for Home Assistant compatibility.
A more precise option for environments that require long-term stability. Similar ESPHome setup required for Home Assistant integration.Use case: Set up an automation to turn on a dehumidifier when the humidity level rises above 65%, preventing mold in damp areas.
This sensor not only measures temperature and humidity but also tracks air quality metrics, providing a holistic view of your environment. It integrates with Home Assistant using ESPHome.
Use case example: Set up an automation to turn on a dehumidifier when the humidity level rises above 65%, helping to prevent mold growth in damp areas like basements or bathrooms. Alternatively, create an automation that adjusts your HVAC system to maintain optimal indoor temperature throughout the day.
2. Air Quality Sensors
Good indoor air quality is essential, especially for homes with allergies or asthma. These sensors help you automate air purifiers or ventilation systems based on real-time data:
Tracks VOCs and gases. Although not natively supported, you can integrate it using ESPHome to automate ventilation systems when air quality drops.
Ideal for indoor areas prone to air pollution, such as kitchens. Integration with ESPHome is required for Home Assistant compatibility.
This dust sensor is great for monitoring fine particulate matter in urban homes or those near construction sites. Integrates easily with ESPHome.
A great solution for general air quality monitoring in home spaces. It tracks VOCs and dust particles, providing vital information for automating air purifiers.
This sensor measures CO2, temperature, and humidity, making it ideal for offices or classrooms. You can set it up with ESPHome for Home Assistant automation.
Use case example: Automate your air purifier to activate when air quality falls below a specific threshold, such as when VOC levels exceed safe limits or PM2.5 dust particles are detected. This can help maintain clean air inside your home, especially during high-pollution periods.
3. Motion and Presence Sensors
A highly accurate presence sensor for Home Assistant. Works seamlessly with Home Assistant using ESPHome for automating lights or appliances based on human presence.
Great for automating security systems or motion-based lighting. This sensor can detect movement at a distance and is compatible with ESPHome.
Ideal for more precise indoor motion detection. Easily integrates with ESPHome for advanced presence detection automation.
Fully Zigbee compatible, this sensor works natively with Home Assistant, perfect for automating lights or cameras upon motion detection.
Use case example: Automate hallway or room lights to turn on when the motion sensor detects movement and turn off after a set period of inactivity. This saves energy while adding convenience. You can also use the sensors to trigger security cameras when unexpected motion is detected. 4. Water and Soil Sensors
These sensors help with garden care or detecting potential water leaks:
Integrates with ESPHome to provide soil moisture readings for Home Assistant, allowing you to automate irrigation systems.
A more advanced soil moisture sensor, also ESPHome-compatible, to optimize garden or greenhouse watering.
Use case example: Automate your irrigation system to activate when the soil moisture drops below a certain threshold, ensuring your garden or indoor plants receive water at the right time. You can also set up notifications to remind you when it’s time to water your plants manually.
5. Door and Window Sensors
Enhance home security with automation that triggers alerts or actions when doors or windows open:
A Zigbee door/window sensor, fully compatible with Home Assistant. Use it to automate lights or security alerts when doors open.
Another Zigbee option, seamlessly integrates with Home Assistant for reliable door and window status monitoring.
Use case example: Create an automation where your porch light turns on when the front door is opened at night, or trigger an alarm if a window is opened when you’re away from home. You can also receive a notification on your phone if any door or window is left open for too long.
6. Light Sensors
Control indoor lighting based on ambient light conditions:
Useful for automating room lighting based on the time of day or outdoor light levels. ESPHome is needed for Home Assistant integration.
Similar to the Light Sensor v1.2 but offers more detailed ambient light data for use in advanced smart lighting automations via ESPHome.Use case: Automate living room lights to adjust based on natural light conditions, ensuring a comfortable environment while saving energy.
Use case example: Automate your indoor lighting to adjust based on the amount of natural light entering the room. For example, you can dim your living room lights as the sun sets, creating a comfortable atmosphere while reducing energy consumption.
7. Additional Sensors
A budget-friendly motion sensor for small space automations like closets or bathrooms. Works with ESPHome for Home Assistant.
Grove – Ultrasonic Distance Sensor
Perfect for parking sensors or monitoring object distances. Set up with ESPHome to track vehicle movement in your garage.
Detects various harmful gases. Suitable for industrial or home settings, but requires ESPHome for Home Assistant compatibility.
Useful for automating humidifiers based on humidity data. ESPHome is needed for Home Assistant integration.
8. Display and Indicators
Conclusion
Integrating the right sensors with the Home Assistant hub enhances your home’s automation potential.
Sonoff Zigbee sensors are natively compatible, while Grove and mmWave sensors require additional setup through ESPHome.
Whether you’re looking to monitor air quality, automate lighting, or manage soil moisture, these sensors provide powerful solutions for elevating your smart home experience.
Liyan Gong
10 years in the IoT hardware industry. I’m here to share practical guides on Home Assistant, NVIDIA Jetson, Meshtastic/Meshcore, Raspberry Pi, LoRa, PCB/PCB Assembly and more to help bring your creative ideas to life.
