Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
The XIAO ePaper Display Board - EE04 is compatible with Sensecraft HMI v1.0, our newly released no-code UI design platform.
  • Powered by XIAO ESP32-S3 Plus:Works immediately when connected to a compatible ePaper display.
  • Versatile Display Support: Compatible with a wide range of ePaper screens, supporting both 24-Pin and 50-Pin interfaces with easy switching via jumper caps.
  • BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
  • User-Friendly Buttons: Includes 1 reset button and 3 user-programmable buttons, offering flexibility for project acceleration and customizable functions.
  • No-Code UI Design & Deployment with SenseCraft HMI: Design and deploy personalized dashboards effortlessly with SenseCraft HMI, our new AI-powered no-code platform. Create your UI through simple drag-and-drop elements, choose from our rich templates, or let AI help you. Connect real-time data from web APIs, then deploy your finished dashboard to epaper display with just a few clicks. From design to data configuration to deployment, everything happens seamlessly on one single platform.
Parameter
onBoard MCU
XIAO ESP32-S3 Plus
Compatible ePaper Displays
-24 Pin ePaper
-50Pin epaper
ePaper Connector
-FPC 24 Pin, 0.5mm
-FCP 50 Pin, 0.5mm
Battery Connector
JST 2.0mm
Switch
Battery Power ON/OFF
Power Supply
- 3.7V Li-Battery
- USB Type-C
Button
-1x Reset button
-3x User button
Hardware Overview
  • NFC Antenna Pins not applicable to this board.
Note Change Record
2025/11/21, Upgrade the PMIC from ETA6003 to SY6974B.
Application
  • Smart Home Dashboard: Display real-time information such as weather updates, calendar events, and notifications from various smart home devices.
  • Energy Monitoring: Show energy consumption data from smart meters, helping homeowners track and manage their energy usage more efficiently.
  • Security Alerts: Display alerts and notifications about security events, such as motion detection or door/window sensor activation.
  • Digital Photo Frame: Create a WiFi-enabled digital photo frame that can display images from your smart home network.
ePaper Board Selection Guide
Product
ePaper Display Board EE02
ePaper Display Board EE04
ePaper Display Board EN04
Driver Board
Breakout Board
Processor
XIAO ESP32-S3 Plus
XIAO ESP32-S3 Plus
XIAO nRF52840 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
13.3" spectra™ 6 E-Ink
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
24 Pin ePaper (NOT for 2.9" BWRY & 7.5" BW)
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
Button
1x Reset
3x User
1x Reset
3x User
Extension IO Port
SenseCraft HMI
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO ESP32-S3 Plus
XIAO ESP32-S3 Plus
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
Button
1x Reset,
3x User
1x Reset,
3x User
1x Reset
3x User
1x Reset
3x User
Extension IO Port
SenseCraft HMI
Certification
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8543709099
COOCHINA
XIAO ePaper Display Board EE04
×1
24Pin Adapter and 24Pin FFC Extension Cable
×1
50Pin Adapter and 50Pin FFC Extension Cable
×1
2.4GHz FPC Antenna (2.9dBi)
×1
XIAO ePaper Display Board(ESP32-S3) - EE04
SKU 100075670
Powered by XIAO ESP32-S3 Plus, the display board EE04 supports both 24-pin and 50-pin ePaper displays. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital signage, electronic labels, and portable information boards.
USD$9.90
You may also add
