Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Built in XIAO ESP32-S3 Plus:Works immediately when connected to a compatible ePaper display.
  • Dedicated 10.3" Monochrome ePaper Display Support: Specifically designed for 10.3" high-speed refresh epaper display with 1404 × 1872 pixels and up to 16-level grayscale, ensuring quick setup and stable operation.
  • High-Speed Refresh Enabled: Integrated T-CON timing control ensures precise high-speed driving, while the onboard SHT40 provides real-time temperature sensing for waveform compensation.
  • BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
  • User-Friendly Buttons: Features 1 reset button and 3 user-programmable buttons, providing flexibility for project acceleration and customizable functions.
  • SenseCraft HMI Firmware Pre-Flashed: Simply plug in and start right away with SenseCraft HMI, our AI-powered no-code UI design platform. Choose from rich templates or drag-and-drop UI building (with optional AI assistance), and deploy to the ePaper display in just a few clicks.
Note:
Occasional high-frequency sound may occur during operation. This is normal due to the ePaper power circuit and does not affect performance.
Parameter
Processor
XIAO ESP32-S3 Plus
ePaper Connector
FPC 40 Pin 0.5mm
Battery Connector
JST 2.0mm
Switch
Battery Power ON/OFF
Power Supply
- 3.7V Li-Battery
- USB Type-C
Button
-1x Reset button
-3x User button
Hardware Overview
Application
  • Digital E-Book Readers: Deliver a paper-like monochrome reading experience with 16-level grayscale and fast refresh for smoother page turns and more responsive updates.
  • Real-Time Dashboard: Display live information such as weather updates, calendar schedules, key notifications, and data widgets like energy usage, sensor status, or KPIs.
  • Security Alerts: Display alerts and notifications about security events, such as motion detection or door/window sensor activation.
  • Public Transit Arrival Board: Show real-time bus/train arrival times, route status, and service alerts at a glance for daily commuting.
ePaper Board Selection Guide
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO ESP32-S3 Plus
XIAO ESP32-S3 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
Button
1x Reset,
3x User
1x Reset,
3x User
1x Reset
3x User
1x Reset
3x User
Extension IO Port
SenseCraft HMI
Certification
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8471707000
COOCHINA
XIAO ePaper Display Board EE03
×1
40Pin Adapter and 40Pin FFC Extension Cable
×1
2.4GHz FPC Antenna (2.9dBi)
×1
XIAO ePaper Display Board EE03 for 10.3" Monochrome ePaper Display
SKU 100080566
Powered by XIAO ESP32-S3 Plus, the ePaper driver board EE03 supports 10.3" Monochrome ePaper Display with 1404 × 1872 pixels and up to 16-level grayscale. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital e-book readers and information boards.
USD$32.90
You may also add
